Activity › Forums › Adobe After Effects › Pre composited layer looks different than the original ones
  • Tudor “ted” jelescu
    August 23, 2012 at 12:52 pm
    It would be helpful if you post a screen grab of your AE interface for us to see how you are building this.
    From the looks of it I would say that you probably have one or several layers with a transfer mode that is set to Screen or Add- I am referring to the blue glow. If that is the case they will interact differently with the background when they are precomposed and that will give you a different look.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Kevin Longe
    August 23, 2012 at 1:00 pm
    That was more than enough 😀 The layers were on add so when I put the pre composited layer on add it was all fixed. Thanks a bunch mate, you have been a great help 🙂
