Activity Forums Adobe After Effects Pre-compose layer/keys visible in final comp?
  • Pre-compose layer/keys visible in final comp?
    Posted by Bali.cogerino on March 13, 2007 at 9:59 am
    Hello,
    Is it possible to see the layers and/or the keys of a pre-composed anim into the final anim to be able to align keys with the fianl comp?
    Thanks for any tricks!
    Bali
    Bali.cogerino replied 19 years, 6 months ago 2 Members · 2 Replies
  • Mark
    March 13, 2007 at 10:58 am
    You could open multiple comp views to see the precomp and final. Then you simply move the layers in the precomp and see the feedback from the final. You can also use guides…
    Hope I am understanding correctly.
    Mark
  • Bali.cogerino
    March 13, 2007 at 11:27 am
    Yes, you did.
    Will try that!
