Activity › Forums › Cinematography › practical levitating effect
Posted by John Shand on October 16, 2013 at 4:46 pmHi All,
I want to try and make it look like someone is levitating through a park. (man levitating, people watching in awe etc.)
Does anyone have any advice or tips or know of any rig we can build to make the effect?
We won’t be shooting a full body shot (unless you guys know a way) so really it will just be the top half of the body and the feet hovering a few inches from the floor.
Has this been done practically before? I’m sure I’ve seen it somewhere.Any advice would be much appreciated.
Thanks for your time.
John
John Shand replied 12 years, 10 months ago 3 Members · 6 Replies -
John Shand
October 16, 2013 at 5:18 pmThe hover board chase on Back to the Future (see link). Is the type of effect I want to pull off when they cut to the top half of their body.
https://www.youtube.com/watch?v=TkyLnWm1iCsSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Mark Suszko
October 16, 2013 at 9:34 pmBut if you don’t show a full body at any point, how do we *know* it’s a levitation?
John Fishback
October 17, 2013 at 4:59 pmI’ve not done this exact kind of effect, but I’d suggest you experiment with shooting on a green screen. Suspend the guy with a wire or two so you can orient him the way you want. Shoot him full frame and CUs as desired. Also, a large fan so his hair and clothes move in the “wind.” You’ll need to remove the wires in post. Plan out your shots so he’s looking in the right direction and “noticing” things in the park. Maybe he waves a couple of folks. Be sure to test (from green screen through post) before shooting for real.
John
MacPro 8-core 2.8GHz, 16 GB RAM, OS 10.8.4, QT10.1, Kona 3, Dual Cinema 23, ATI Radeon HD 5870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
FCP-X 10.0.9, Motion 5.0.7, Compressor 4.0.7Pro Tools HD 10 w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec DSP Monitors, Prima CDQ120 ISDN
John Shand
October 17, 2013 at 5:10 pmThanks John, that is some great advice.
Mark, we plan to show the feet floating along the floor then cut to the upper body when he is passing people etc.
Do you know the best way to show the feet rising from the ground? We want the opening shot to be the feet walking through the park then they start to float off the floor. Is there a device or something we can build that will help our actor into this transition?
Appreciate the advice so far.
John -
Mark Suszko
October 17, 2013 at 9:14 pmIf you only need to see the legs/feet, then a simple zipline he can hang from, that gradually slopes up, can get you that effect on site.
A famous “practical” floating effect was the close-ups of the land speeder in Star Wars, which was suspended on a large jib-like arm that rotated it into the shot. In “Dark Star”, dangling beneath an elevator was hysterically yet concincingly done by tilting the camera at a dutch angle in a corridor made to look like an elevator shaft. A forklift drove back and forth up and down the corridor, with a fake elevator “floor” attached to the front tines area. A stiff board attached to one tine is what the actor rested on with his pants covering the board. The overall effect was dangling dangerously, in a 13-story shaft, going up and down, while never being more than 2 feet from a real floor.
The “wireless” way to do flying green screen is to shoot down from above, towards a green floor, with the actor standing on one foot, looking up into the camera and pantomiming zero-gee. The actor could also lay on a green box or other support.
