Activity Forums Adobe Premiere Pro Pr CS4 – screen capture edit
  • Pr CS4 – screen capture edit
    Posted by Uri Soglowek on October 23, 2008 at 12:48 pm
    i am trying to export a screen capture movie that was done with Snapz Pro (and was saved as .mov with Amination preset) but every time i render it out with premiere it doesn’t look good.
    any advice?
    uri
    Mike Wach replied 17 years, 6 months ago 3 Members · 3 Replies
  • Eddie Lotter
    October 23, 2008 at 1:16 pm
    1. What are the details of your source clip?
    2. What are the details of your project settings?
    3. What are the details of your export settings?
    Cheers
    Eddie
  • Uri Soglowek
    October 23, 2008 at 2:49 pm
    Hi Eddie,
    thanks for the fast respond.
    this is the situation:
    i recorded a screen capture clip with Sbapz Pro (but the same also happened with ScreenFlow) and save the clip to QT animation.
    then i opened up premiere and edited the video in a sequence. i then exported the video to the media encoder and encoded it with the same settings – QT animation.
    the sequence settings were –
    Pixals aspect ration – square
    Progressive scan
    the same FPS as the recording
    the same audio settings as the recording
    video preview – QT animation
    when i sent to the media encoder and renderd it with the same settings:
    Progressive scan
    QT animation
    i got horrible looking video. this does not happen with CS3 or cs2 and in-fact the same video rendered out as AVI with no compression has no problem
    (needless to say i tried to render to QT with None chosen under Codec. this doesn’t work either.)
    i have to admit i am new to Mac.
    is there a way to render from Pr CS4 in the same fashion as in Pr CS3 – file>export>movie.
    i never used the media encoder in the past but it looks like there is no other option in CS4.
    thanks for the help.
    uri
  • Mike Wach
    March 11, 2009 at 12:29 am
    Hello All,
    I am having the same problem. I am using
    Snapz Pro on Mac OSX Leopard
    with Adobe Premiere Pro CS4 and Adobe Media Encoder CS4
    No matter what settings I try, all of my exports result in low quality, blurry, and/or distorted video. I have tried H.264, Quicktime, and even exporting a Targa image sequence. None of them seem to work. When exporting with Quicktime and the MPEG-4 compressor, the video exports successfully but is low quality/distorted. When I try to export using Quicktime and the “Animation” or “None” compressor settings, Adobe Media Encoder stalls at about 99% render completion. You press the pause and resume buttons as many times as you want but they don’t do anything. The render stays frozen at 99% infinitely. Pressing the ‘stop’ button simply crashes Adobe Media Encoder.
    This problem is driving me crazy and I think its safe to say I’m interested in an alternative screen capture program. Snapz just doesn’t seem meant to be for editing with Premiere Pro CS4. Unless someone can please prove otherwise.
    Attached below is my Adobe Media Encoder log…
    -Mike Wach
    Tue Mar 10 02:05:16 2009 : Queue Started
    – Source File: /Users/Mike/Library/Caches/TemporaryItems/Meeting 04_1.prproj
    – Output File: /Users/Mike/Desktop/Meeting 04/Meeting 04.mp4
    – Preset Used: Screen Capture 1024
    – Video: NTSC, 1024×768, 29.97 [fps], Progressive
    – Audio: AAC, 192 [kbps], 48 kHz, Stereo
    – Bitrate: VBR, 1 Pass, Target 3.00, Max 6.00 [Mbps]
    – Encoding Time: 00:37:04
    Tue Mar 10 02:45:12 2009 : File Successfully Encoded
    Tue Mar 10 02:45:29 2009 : Queue Stopped
    Tue Mar 10 03:06:46 2009 : Queue Started
    – Source File: /Users/Mike/Library/Caches/TemporaryItems/Meeting 04_2.prproj
    – Output File: /Users/Mike/Desktop/Meeting 04/Meeting 04_1.mp4
    – Preset Used: Custom
    – Video: No Summary Available
    – Bitrate: No Summary Available
    – Encoding Time: 00:00:34
    Tue Mar 10 03:11:06 2009 : File Successfully Encoded
    Tue Mar 10 03:11:08 2009 : Queue Stopped
    Tue Mar 10 03:31:42 2009 : Queue Started
    – Source File: /Users/Mike/Library/Caches/TemporaryItems/Meeting 04_4.prproj
    – Output File: /Users/Mike/Desktop/Meeting 04/Meeting 04.mov
    – Video: 1024×768, 29.97 [fps], Progressive, Quality 100
    – Audio: 48000 Hz, Stereo, 16 bit
    – Bitrate: MPEG-4 Video
    Tue Mar 10 11:28:07 2009 : Queue Paused
    Tue Mar 10 11:28:09 2009 : Queue Resumed
    Tue Mar 10 11:42:23 2009 : Queue Started
    – Source File: /Users/Mike/Library/Caches/TemporaryItems/Meeting 04_5.prproj
    – Preset Used: Apple iPod Video Large
    – Video: NTSC, 640×480, 30 [fps], Progressive
    – Audio: AAC, 128 [kbps], 48 kHz, Stereo
    – Bitrate: VBR, 1 Pass, Target 1.00, Max 1.40 [Mbps]
    Tue Mar 10 12:02:08 2009 : Queue Paused
    Tue Mar 10 12:06:23 2009 : Queue Resumed
    – Encoding Time: 00:39:02
    Tue Mar 10 12:23:58 2009 : File Successfully Encoded
    Tue Mar 10 12:24:16 2009 : Queue Stopped
    Tue Mar 10 12:56:21 2009 : Queue Started
    – Source File: /Users/Mike/Library/Caches/TemporaryItems/Meeting 04_6.prproj
    – Video: 1024×768, 10 [fps], Progressive, Quality 100
    – Bitrate: Animation
    Tue Mar 10 13:11:15 2009 : Queue Paused
    Tue Mar 10 13:11:18 2009 : Queue Resumed
    Tue Mar 10 13:12:05 2009 : Queue Paused
    Tue Mar 10 13:13:22 2009 : Queue Resumed
    Tue Mar 10 13:25:08 2009 : Queue Started
    – Source File: /Users/Mike/Library/Caches/TemporaryItems/Meeting 04_7.prproj
    – Bitrate: None
    Tue Mar 10 15:32:28 2009 : Queue Started
    – Encoding Time: 65:17:35
    Tue Mar 10 15:35:26 2009 : File Successfully Encoded
    – Source File: /Users/Mike/Library/Caches/TemporaryItems/Meeting 04_8.prproj
    – Output File: /Users/Mike/Desktop/Meeting 04/Meeting 04.tga
    – Video: 1024×768, Progressive
    – Audio:
    – Bitrate:
    Tue Mar 10 15:35:27 2009 : Queue Stopped
    Tue Mar 10 16:13:12 2009 : Queue Started
    – Source File: /Users/Mike/Library/Caches/TemporaryItems/Meeting 04_9.prproj
    – Output File: /Users/Mike/Desktop/Meeting 04/Targa Sequence/Meeting 04.tga
    – Audio:
    – Bitrate:
    – Encoding Time: 00:14:14
    Tue Mar 10 16:29:02 2009 : File Successfully Encoded
    Tue Mar 10 16:29:07 2009 : Queue Stopped
