Activity › Forums › Adobe Premiere Pro › PProCC2015 not seeing USB 3 RAID in Media Browser (Mac)
  • PProCC2015 not seeing USB 3 RAID in Media Browser (Mac)
    Posted by Oliver Peters on July 30, 2015 at 7:22 pm
    I am unable to use Media Browser to see an external OWC RAID array, which is connected via a CalDigit USB 3.0 PCIe card. In the listing under “Local Drives”, this drive is not displayed. However, when I click on the “Local Drives” label all drives including this RAID show in the righthand pane. I still cannot open it from there. I can open the other drives. Also when I try to use the locate function, it will not see this drive in that dialogue either.
    I can still use import to bring in media from the array and I can drag media into PProCC by using the Finder. Import and export from PProCC work just fine. All other software on this system (FCPX, Resolve, etc.) see this array without issue.
    2010 MacPro 12-core, OSX 10.10.4. All Adobe CC apps are current up through today’s round of updates (7/30).
    Thoughts? TIA.
    – Oliver
    Orlando, FL
    http://www.oliverpeters.com
    Oliver Peters replied 11 years, 1 month ago 5 Members · 15 Replies
  • 15 Replies
  • David Roth weiss
    July 30, 2015 at 11:26 pm
    I’m really reaching here Oliver, as I have no tangible experience with the exact variables you’re dealing with now. That being said, if I were you, at some point I would consider backing up the RAID, then reformatting it under your latest version of Yosemite. There just might be some minor bit or byte that’s been changed in the formatting or configuration that makes a difference. I have encountered stuff like this in the past.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions
    David is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
  • Oliver Peters
    July 30, 2015 at 11:34 pm
    [David Roth Weiss] “I would consider backing up the RAID, then reformatting it under your latest version of Yosemite.”
    It’s brand new and was formatted about a week ago under 10.10.4. This seems to be entirely a Premiere issue – either with the RAID or the CalDigit card. I’m not seeing any issues with any other application or with any other part of Premiere and this RAID.
    – Oliver
    Orlando, FL
  • David Roth weiss
    July 31, 2015 at 12:08 am
    Well, that’s a horse of a different color, and is definitely something that defies both reason and logic. Don’t you just hate dealing with issues to which reason and logic do not apply?
    David Roth Weiss
  • Oliver Peters
    [David Roth Weiss] “Don’t you just hate dealing with issues to which reason and logic do not apply?”
    Yep! 😉
    – Oliver
    Orlando, FL
  • Paul Neumann
    July 31, 2015 at 3:12 am
    I had a somewhat similar situation right after the latest release. Uninstall/reinstall of Media Encoder fixed it for me. Not as specific as your problem, but things not showing up in Media Browser but there in the finder, Favorites coming and going, etc.
  • Oliver Peters
    July 31, 2015 at 1:03 pm
    [Paul Neumann] “Uninstall/reinstall of Media Encoder fixed it for me”
    Thanks. Just tried that. No luck. FWIW – other single drives connected to this CalDigit USB3 card appear properly under Media Browser.
    – Oliver
    Orlando, FL
  • Alex Udell
    July 31, 2015 at 3:28 pm
    what happens if you alias a folder from the RAID to a location you can get to via browser?
    Alex Udell
    Editing, Motion Graphics, and Visual FX
  • Oliver Peters
    July 31, 2015 at 4:12 pm
    [Alex Udell] “what happens if you alias a folder from the RAID to a location you can get to via browser?”
    Interesting. Yes, I created an alias of my Projects folder from the RAID and placed that on the desktop. I can access and open that in Media Browser. It’s a good workaround, but what does that mean? Is that a clue to a better fix?
    – Oliver
    Orlando, FL
  • Alex Udell
    July 31, 2015 at 4:22 pm
    Hi Oliver…
    Everything you’ve described plus that result indicates pretty clearly it’s bug to me.
    I’d report it and work around that way until they fix.
    Or that’s to say I can’t think of a better way to work around it for now.
    sorry…but at least you’re not locked out of your RAID.
    Alex Udell
  • Oliver Peters
    July 31, 2015 at 9:14 pm
    [Alex Udell] “sorry…but at least you’re not locked out of your RAID.”
    OWC’s recommendation is to repartition the RAID (same as David suggested). I can’t do that until a few weeks from now as I’m in mid-project. I’ll do that then and post back if indeed it provides a solution.
    – Oliver
    Orlando, FL
