Activity Forums Adobe Premiere Pro PPro on late 2008 MBP, Intel Core 2 Duo, 2.8GHz, 8GB RAM?
  • PPro on late 2008 MBP, Intel Core 2 Duo, 2.8GHz, 8GB RAM?
    Posted by Isaac Brillant on June 17, 2013 at 11:54 am
    I’ve read the system requirements for PPro on Adobe’s site, but I’m not sure if my late 17″ 2008 MBP fits the requirements. Their site keeps crashing so I’m posting here. Can someone help me out? Will I be able to run it? Here’s what I’ve got. Thanks!
    Hardware Overview:
    Model Name: MacBook Pro
    Model Identifier: MacBookPro5,1
    Processor Name: Intel Core 2 Duo
    Processor Speed: 2.8 GHz
    Number Of Processors: 1
    Total Number Of Cores: 2
    L2 Cache: 6 MB
    Memory: 8 GB
    Bus Speed: 1.07 GHz
    Boot ROM Version: MBP51.007E.B06
    SMC Version (system): 1.33f8
    Hardware UUID: C7CC23FB-BE88-567F-B52A-3F1B430EC131
    Sudden Motion Sensor:
    State: Enabled
    System Software Overview:
    System Version: Mac OS X 10.6.8 (10K549)
    Kernel Version: Darwin 10.8.0
    Boot Volume: Macintosh HD
    Secure Virtual Memory: Enabled
    64-bit Kernel and Extensions: No
    Graphics/Displays:
    NVIDIA GeForce 9600M GT:
    Chipset Model: NVIDIA GeForce 9600M GT
    Type: GPU
    Bus: PCIe
    PCIe Lane Width: x16
    VRAM (Total): 512 MB
    Vendor: NVIDIA (0x10de)
    Device ID: 0x0647
    Revision ID: 0x00a1
    ROM Revision: 3437
    gMux Version: 1.7.3
    Displays:
    Display Connector:
    Status: No Display Connected
    Display Connector:
    NVIDIA GeForce 9400M:
    Chipset Model: NVIDIA GeForce 9400M
    Type: GPU
    Bus: PCI
    VRAM (Total): 256 MB
    Device ID: 0x0863
    Revision ID: 0x00b1
    ROM Revision: 3437
    gMux Version: 1.7.3
    Displays:
    Color LCD:
    Resolution: 1440 x 900
    Pixel Depth: 32-Bit Color (ARGB8888)
    Main Display: Yes
    Mirror: Off
    Online: Yes
    Built-In: Yes
    Display Connector:
    Isaac Brillant replied 12 years, 11 months ago 3 Members · 5 Replies
  • Kris Merkel
    June 17, 2013 at 1:15 pm
    It will work but not as smooth as a newer model with a better graphics card and faster processors. You will also need to double the amount of installed RAM as 8GB is not enough for the memory pool.
    “Think of everything in terms of building capacity.”
    Kris Merkel
    twitter: @kris_merkel
    Product Manager, Flanders Scientific Inc.
    http://www.shopfsi.com
    Co-Founder, Atlanta Cutters Post Production User Group
    http://www.atlantacutters.com
    2.2Ghz MBP core i7
    16Gb RAM
    CS6/FCP7
    AJA T-Tap
    AJA IO XT
    FSI LM-2461W/CM-170W
  • Isaac Brillant
    June 17, 2013 at 1:41 pm
    Thanks for the reply. Good to know.
    What pool?
    I think 8GB is the max that I can install in my model MBP 🙁
  • Kris Merkel
    June 17, 2013 at 1:47 pm
    That MBP should support 16Mb of RAM. the memory pool is adobe’s way of allocating memory to the CC apps that need it the most.
    Kris Merkel
    2.2Ghz MBP core i7
    16Gb RAM
    CS6/FCP7
    AJA T-Tap
    AJA IO XT
  • Al Bergstein
    June 18, 2013 at 2:08 pm
    I have run CS 6. on a MBP with 8 GBs. It does work. But I agree, while your MBP will work, it is not an optimum situation. Be sure to have enough hard disk free and use an external FW800 or esata card express card for all your media. Start saving for an upgrade (G).
    Al
  • Isaac Brillant
    June 19, 2013 at 7:43 pm
    Thanks for your reply. I just installed PPro on my old MBP, and you’re right, it works. So long as I have it on 1/4 quality playback. I’ll try installing 16GB of Ram, and will stick to eStaa instead of firewire.
    thanks!
