Activity › Forums › DaVinci Resolve › PPro CS6 XML to Resolve
  • PPro CS6 XML to Resolve
    Posted by Jim Bachalo on June 3, 2014 at 12:34 pm
    Read this post over on the film bakery blog about a one way workflow using FCP and Resolve for finishing.
    https://www.thefilmbakery.com/blog/one-way-trip-with-resolve-10
    Was excited to see if I could get it to work using PremierePro CS6.
    My sequence in PPro was standard, although I had 1 dynamically linked clip from After Effects.
    The result of my export-import was that ALL my audio files failed to be imported , the dynamically linked After effects clip didn’t make it, and many of my remaining clips were improperly scaled even though I clicked retain sizing info.
    What a mess!
    The error message I get is
    The clip ‘foo’ failed to link because the media file’foo’ is missing or has the wrong timecode extents.
    Is this a wasted exercise for Premiere pro?
    Is it impossible to properly import dynamically linked clips?
    Will I have better luck using FCPX?
    You should follow me on Twitter here. My latest work
    Jim Bachalo replied 12 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
