Activity Forums Adobe Premiere Pro PPro CS6 AVCHD Workflow
  • PPro CS6 AVCHD Workflow
    Posted by Jay Luka on June 22, 2012 at 2:49 pm
    Hi all,
    I am a longtime FCP editor that has recently moved to PPro CS6.
    For years my footage came to me at DVCProHD 1080p 24fps. I would edit in FCP at ProRes and export a Quicktime using my timeline settings which I would then use in Compressor (MPEG Streamclip, Handbrake…) to create all of my FLV, MPEG-2, MP4 files from. Maybe not the best workflow, but for the type of work I was doing, 2-5 min videos for the web, it was fast and efficient.
    I’d like to work similarly with PPro, but many variables have changed. First, I’m using PPro on a slower Mac (2.4 GHz Core 2 duo w/ 4 GB Memory, I know, I need to upgrade), my footage is AVCHD from a AG100 and the videos are MUCH longer. 2-3 hours in some cases. The destination is also different, usually Blue-Ray DVD and Vimeo.
    I’m also finding that the AVCHD format is not near as nice as DVCProHD. MTS files are kind of a pain to work with, but I have been using the camera native AVCHD 1080p 24p codec to edit with and just using the sequence presets to export my hi res master file.
    My longwinded question is this: What do you think would be the best sequence presets to use to keep the quality up while not killing myself with render and export?
    Thanks in advance,
    Jay
    Todd Kopriva replied 13 years, 1 month ago 3 Members · 2 Replies
  • Randy Mcwilson
    June 29, 2012 at 5:23 pm
    Jay:
    The first problem that needs to be resolved is the bug in CS6 (acknowledged by Adobe) when working with long format, spanned MTS clips. CS5 and 5.5 handled these quite well, but CS6 stutters, and then freezes when you try to playback these spanned clips.
    Once that is resolved, the best would be to use the AVCHD presets built into PPRo, and then use media encoder to export.
    Eternity…don’t miss it for the world.
  • Todd Kopriva
    August 15, 2013 at 1:14 am
    The Premiere Pro CS6 (6.0.4) update fixes the spanned AVCHD clip bug and more: https://bit.ly/DVA_updates
    After Effects team blog
