Activity Forums Adobe Premiere Pro PPro CS4 Dual monitor problem
  • PPro CS4 Dual monitor problem
    Posted by Simon Davis on September 14, 2009 at 10:35 pm
    Hello, I’m trying to get a second monitor to work. I’ve set it up in the Sequence Settings>Playback Settings to use a second monitor to show video. The second monitor goes black, the ‘monitor’ application shows up in the task bar but the screen remains black instead of showing the video. I’m using a nVidia 9600GT graphics card.
    I’ve noticed if I drag PPro to the second monitor, neither the Program or Source monitors show their video, only in the primary monitor. I can play Windows Media Player video in the second monitor and PPro in the primary, simultaneously. I can’t see whether this is a graphics card or PPro problem?
    Thanks for any help.
    Simon
    Simon Davis replied 17 years ago 2 Members · 8 Replies
  • 8 Replies
  • Brian Louis
    September 15, 2009 at 9:09 am
    Do you have the latest drivers for the vid card? I’ve got some 9600s on a couple of machines and can view on a second monitor with no problem.
  • Simon Davis
    September 16, 2009 at 3:14 pm
    Hello, yes I have, I updated a couple of days ago.
  • Brian Louis
    September 16, 2009 at 9:24 pm
    Did you have this problem before you updated the drivers and attempted to fix it by updating.
  • Simon Davis
    September 17, 2009 at 8:36 am
    Yes, I did. I’m using a 1920×1200 Samsung as primary and 1680×1050 HP as secondary.
  • Brian Louis
    September 17, 2009 at 9:05 pm
    Try reducing the resolution a step or two on the large monitor and see if the overlay comes back on the smaller monitor
  • Simon Davis
    September 18, 2009 at 2:28 pm
    Hello,
    I’ve tried lowering the Samsung monitor resolution by increasing amounts, but it’s still the same. I suspect the problem’s with PPro.
    Simon
  • Brian Louis
    September 23, 2009 at 10:14 am
    [Simon Davis] “I suspect the problem’s with PPro.”
    There are very few problems running 9xxx series with Ppro, when you setup your dual monitors you are extending your desktop across both monitors?
  • Simon Davis
    September 25, 2009 at 5:23 pm
    Hello,
    No I’m using Dual View with both monitors at their native resolution.
    Simon
