Activity Forums Adobe Premiere Pro PPro CS3 – MainConcept MPEG Pro 3.1 – Encore problem
  • PPro CS3 – MainConcept MPEG Pro 3.1 – Encore problem
    Posted by Juergen Jerzembeck on April 19, 2008 at 2:29 pm
    I´m having problems with re-coding MPEG2 files, exported from PremierePro CS3.2, created with last MainConcept MPEG Pro 3.1, being recognised in Encore as already coded. Encore needs to re-code them in order to write a DVD. What crap! I´ve purchased the MainConcept plugin just for the smart-rendering option in order not to recode whole files after having cut them in PPro.
    Normally I use the “recognise file” option of Mainconcept in order to get the correct setting for the smart-rendering.
    Does anyone have an idea may be where to tune setting in either Encore or PPro/Mainconcept.
    Juergen
    Mike Velte replied 18 years, 5 months ago 2 Members · 1 Reply
  • Mike Velte
    April 20, 2008 at 11:40 am
    Just a quick test exporting an SD clip from CS3/ MC 3.1 Encore CS3 imported it fine with 4 “Dont Transcode” listed in the Project window for the .m2v file.
    https://www.video2stream.com
