Activity › Forums › Adobe Premiere Pro › PPro 5.5, Nvidia 285 and MXO2 Mini
  • PPro 5.5, Nvidia 285 and MXO2 Mini
    Posted by Shane Ross on June 29, 2011 at 6:07 pm
    OK…So I installed Adobe CS5.5 and opened Premiere and all was good. I could import footage, edit…everything. But then I wanted it to work with my Matrox MXO2 mini for external monitoring…and Matrox just released a new update that said it would enable the MXO2 line to do just that. GREAT, so I installed that. And then I took out my ATI graphics card and installed my NVidia 285 that I bought for use with RESOLVE…because the card has CUDA support with Mercury Engine and all that. And after I did that I installed the latest drivers (because there was a messageOK…done.
    But now things don’t work. Not fully.
    First I tried getting my MXO2 to work by choosing Matrox project settings. But when I do that, I cannot see clips I load into the Preview monitor…they are black, and well, act like nothing is there. No timecode, press play, nothing happens. If I drag from the project window into the timeline, the clips appear. But won’t play in the Program monitor. Can’t be seen, press play, nada happens. I Match Back to a clip in the Preview monitor…I see it’s timecode, but no image, and I cannot play.
    Then I made a new project, and chose the settings for the footage I was using…DVCPRO HD 720p24…from P2. Again, I can import, but cannot see anything in the Preview monitor. I can drag the clips onto the timeline, and NOW I can see and hear things in the Program monitor…but still nothing in the preview monitor.
    So this is really messed up and not functioning right at all. Any clues as to why?
    Shane
    Shane Ross replied 15 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
