Activity › Forums › Adobe Premiere Pro › PPro 2.0 on a laptop?
Posted by Brian Deviteri on January 18, 2006 at 12:18 amI just read the minimum specs for PPro 2.0 and I’m a little taken back. I’m running PPro 1.5.1 right now on a 2.0ghz Centrino (Pentium-M) processor that I currently do a lot of DV25 work with and I’ve even messed around with some HDV without any difficutly. Currently running 1gb of RAM, but I can easily upgrade to 2gb if needed, a 60gb 7200rpm hard drive, running WinXP Pro with SP2, 128mb ATI Mobility Radeon Pro Turbo (32-bit) supporting 1680×1050.
According to the minimum specs, this might not be supported:
(from Adobe)
IntelEugene replied 19 years, 11 months ago 8 Members · 14 Replies -
Jacob Rosenberg
January 18, 2006 at 12:23 amSo far I have been running PPro on my Dell laptop, it is a pentium 3.12, it’s beefy and it responds just fine. I do all my road demos and presentations with it. I would think that it would run fine on your system for most to all DV work, in some circumstances it might choke on HDV, but I couldn’t predict that with certaintly.
jacobhttp://www.premiereprotraining.com
http://www.formikafilms.com
http://www.d2gfilm.com -
Brian Deviteri
January 18, 2006 at 1:19 amthanks for the reply Jacob! I can’t wait to read your new book for PPro 2.0…
if you don’t mind my asking, what are the key features that you find in 2.0 that really help you when editing on a laptop?
Tim Kolb
January 18, 2006 at 2:06 amWhile I’m not Jacob, I use a laptop as well…a 3.2 BOXX system.
I’m not sure there are any features that specifically help you edit on a laptop…other than dockable windows do make a single monitor desktop easier to manage for sure.
For HDV, my personal opinion is that CineForm Aspect makes that a workable proposition on most computers…I ran that on a non-HT P4 2.8 Laptop I had and it ran just fine…I doubt I could say that for HDV native.
Otherwise…Premiere Pro is still kind of a handful compared to Vegas or Edius as far as horsepower required…but then I think the feature set makes the tradeoff worth it.
If you run the production studio, you’ll want a LOT of RAM for multiple apps open at once.
TimK,
Kolb Productions,
Creative Cow Host,
Author/Trainer
http://www.focalpress.com
http://www.classondemand.net -
Aanarav Sareen
January 18, 2006 at 2:11 amBrian,
All my editing is done on the newer Centrino laptop. Works just fine. My specs are 2.0ghz, 1GB RAM and an 80gb 7200 rpm drive. -
Eric Lagerlof
January 18, 2006 at 2:50 amAll my editing is done on the newer Centrino laptop. Works just fine. My specs are 2.0ghz, 1GB RAM and an 80gb 7200 rpm drive
You’re referring to DV footage? Do you use HDV footage as well?
Aanarav Sareen
January 18, 2006 at 3:13 amEric,
Primarily I use the laptop to edit DV footage, but I have edited HDV footage, with not not too much difficulty. -
Eric Lagerlof
January 18, 2006 at 3:53 amAanarav, thanks for the reply. Here is my other HDV question. Adobe says something to the effect that editing native HDV keeps you from losing quality. But every time you cut on a non-I frame or add a dissolve or any other video processing you have to leave the MPEG world anyway, correct. So, at least in their preview clips they do what, go to an intermediate codec? Re-render to MPEG automatically? And if you are doing lots of processing, say in After Effects, is the native HDV bit really an advantage?
Brian Deviteri
January 18, 2006 at 11:05 amEric,
This is where I think Cineform will still play a large role in the post-production workflow of many users. As you know, Adobe has opted to move away from Cineform’s intermediary codec for HDV in favor of “native” HDV editing (I think it’s a marketing thing to compete with the other “big” companies). Anyone who has edited with the Cineform intermediary codec knows that the performance is top notch. Yes, it may add a little time to the process (compared to native HDV editing), but when working with the footage during an edit, and the end results, it really is worth it in my opinion. It really makes working with HDV the same as DV in terms of system performance… not much else can live up to that if you ask me.
In the end, what is all boils down to is cost. Do you want to edit HDV natively in PPro without an intermediary? If so, you will need to spend money on a beefier machine to see better results – more CPU, more RAM, faster hard drives, etc. Do you want to edit with an intermediary? If so, you can spend money on that and probably get amazing results through your current setup. Just my two cents…
Brian
Steven L. gotz
January 18, 2006 at 1:36 pmAnd the Cineform intermedate codec uses a wavelet technology that is actually able to provide a higher quality (less loss) editing experience. I, for one, will be using Aspect HD 4.0 on January 20th.
Disclosure: I am Cineform’s biggest fan. Their technology, speed to market, and online support on forums are second to none.
Steven
Adobe Premiere Pro 1.5.1 / After Effects 6.5 Pro https://www.stevengotz.com
Learning Adobe Premiere Pro 1.5 https://www.lynda.com
Contributing Writer, PeachPit Press, Visual QuickPro Guide, Premiere Pro 1.5 -
Eric Lagerlof
January 18, 2006 at 4:13 pmBrian, you offer a good perspective, it is a tradeoff isn’t it? I was disappointed that Adobe didn’t have the snap to offer a choice between ‘native’ editing and the free Cineform plug-in that came with PPro 1.5 in the 2.0 release. Sometimes I think Adobe’s approach to developing and marketing Premiere Pro is based on their approaches to Photoshop and Illustrator. Old-Fashioned and incremmental, as though PPro was being sold primarily to big corporations that could afford the upgrades year after year. PPRo was a change in stride from Premiere but somehow they still haven’t totally clicked into the creative community of small operators or even bigger post houses all that well. I guess they sell a lot of software but here in the San Francisco Bay area, when I look for freelance jobs, I see FCP editors wanted over and over-followed by a sprinkling of Avid editors. Almost no PPro editors needed. I’m reallly torn between PPro and just hopping over to Macs and FCP for greater work ooportunities. Oh well…
