Activity Forums Adobe Premiere Pro PPro 2.0 and AXIO HD
  • PPro 2.0 and AXIO HD
    Posted by Pat Mcgowan on May 4, 2006 at 12:27 am
    We are having the following difficulties:
    1) Timeline renders work fine in SD projects on our AXIO HD box, but will only work in HD projects if s set the video preview scratch disk to the systm drive, otherwise it hangs.
    2) We cannot capture HDV footage via either 1394 interface without the system hagng about 2 seconds into the capture. Must use task manager to end the program.
    Any ideas?
    Pat Mcgowan replied 20 years, 3 months ago 2 Members · 3 Replies
  • Jeff Bellune
    May 4, 2006 at 1:10 am
    Although you may get an answer here, a better choice is the Matrox forum, or even contacting Matrox directly. Twelve grand ought to get you responsive tech support.
  • Pat Mcgowan
    May 5, 2006 at 4:22 pm
    Our situation is a bit odd and I’m hopin someone has an answer wither here or on another forum.
    I don’t see the price tag for the AXI HD system as excessive for what we got. Try pricing a comparable AVID system (sit down first).
  • Pat Mcgowan
    May 10, 2006 at 2:31 pm
    Probelms solved. Our Array was not set up properly by our integrator.
