Activity Forums Adobe Premiere Pro ppro 1.5 clips stuttering after new installation
  • ppro 1.5 clips stuttering after new installation
    Posted by Ut Mansel on August 5, 2005 at 9:55 pm
    hello to the forum,
    first of all I want to apologise my none perfect english.
    some weeks ago I got a new pc-system :
    asus p5ad2-premium (with pci express) / intel p4 3,4 ghz / 2gb ram 533 / 1.hd sataII 200gb / 2. hd ide 200gb /nvidia pcx 5900 /win-xp sp2.
    so I installed ppro1.5 ( updated to 1.5.1 ) several times with always the same problem and finally only ppro and nothing else — started my projects and still…: clips are stuttering. they don`t increase heeps by putting several effects on it, only a little bit, but I
    Ut Mansel replied 21 years ago 2 Members · 5 Replies
  • Mike Velte
    August 6, 2005 at 11:10 am
    Do a test; tramsfer a file about 100 MB from each drive to the other…should take about 3 seconds.
  • Ut Mansel
    August 6, 2005 at 2:30 pm
    thank you very much for your fast response! I`ve tried so and it took even 3 seconds from sata hd (program hd) to ide hd (footage hd) and the other way less than 2 sec!
    that
  • Mike Velte
    August 6, 2005 at 7:43 pm
    Suspect a video card problem…update its drivers.
    Also try switching the last item in “Playback settings”.
  • Ut Mansel
    August 6, 2005 at 8:50 pm
    at first the whole system is updated with the latest drivers (august 05)
    I
  • Ut Mansel
    August 9, 2005 at 7:19 pm
    quiet unbelievable!!! I removed service pack 2 , installed service pack 1 and….the program works solid.
    “Lightly” angry when I think about all the work we`ve had over the last weeks
    although thanks very much Mike Velte for trying to find a solution!
    *uT mansel
