Activity Forums Adobe Premiere Pro PPCC 2015 – unable to use “fit to fill” / “fit clip” window even though correct track selected with V1
  • PPCC 2015 – unable to use “fit to fill” / “fit clip” window even though correct track selected with V1
    Posted by Nicholas Natteau on June 26, 2015 at 3:01 am
    I turns out that I selected the wrong option when I tried to do a fit to fill edit, and now I have no way of getting back to that window “Fit Clip”
    so that i can select “fit to fill”
    Does anyone know how to get that window to pop up again. I can’t find it anywhere. I have the correct track selected.
    But even though I have four edit points set, PPCC is not executing the fit to fill edit. I don’t know what i did wrong but i can’t get that window back.
    Nicholas Natteau replied 11 years, 2 months ago 1 Member · 1 Reply
  • Nicholas Natteau
    June 26, 2015 at 3:05 am
    Never mind, just solved the problem. I found it in the General Prefs, first section: “Fit Clip Dialog opens for edit range mismatch”. Phew!
