Activity Forums Adobe Premiere Pro PP7 Sound Cutoff Problem
  • PP7 Sound Cutoff Problem
    Posted by Sleddriver1 on January 26, 2007 at 12:59 pm
    I’m working with a new install of PP7 on a fresh install of XP after a motherboard failure and replacement. Before the failure PP7 worked flawlessly. Now, when I render projects it cuts off the sound about 4 to 5 seconds before the end of the project. The video continues to be rendered, but not the audio. I’ve had to resort to extending my work area bar by 5 seconds just to get all the sound that I should be getting.
    Is this a PP7 bug? Any suggestions?
    Sleddriver1 replied 19 years, 8 months ago 3 Members · 9 Replies
  • 9 Replies
  • Mike Velte
    January 26, 2007 at 3:23 pm
    After a new Windows install, make sure you reinstall newest factory drivers;
    Sound Card
    Video Card
    Motherboard chipset drivers
  • Sleddriver1
    January 26, 2007 at 4:02 pm
    I did…latest and greatest of everything. What’s odd is, PP7 plays the film fine in the Monitor panel…plays it exactly as I have constructed it. It’s in the final rendered AVI file that the sound drop occurs.
  • Blast1
    January 26, 2007 at 7:19 pm
    If you used the same harddrive with previous loaded programs and drivers, the best way is to reformat and reload, gets rid of possible trouble causing files that reinstallations don’t.
  • Mike Velte
    January 26, 2007 at 7:44 pm
    Try exporting just the audio as a .wav (48 kz) file. If that plays fine Then turn off the audio tracks and export the video as mpeg for dvd…load both into Encore, author and burn.
    https://www.video2stream.com
  • Sleddriver1
    January 26, 2007 at 8:19 pm
    I started 100% from scratch: brand new HD, brand new XP install, brand new PP7 install, etc…I didn’t want to risk registry nightmares…
  • Sleddriver1
    January 26, 2007 at 8:21 pm
    Thanks; I could probably also leverage AE6.5 for a similar process. But I just hate workarounds when something worked perfectly before.
  • Sleddriver1
    January 26, 2007 at 11:43 pm
    Now things are weirder. I can render the audio-only track to an AVI file, and it renders in full. When I checkmark the box to render video also, the audio cuts out about 5 seconds before the end of the resulting AVI file. AAUGGHHH!!!!!!
  • Mike Velte
    January 27, 2007 at 12:12 pm
    Version 7 had more than its share of bugs, but I dont recall this one. When the audio cuts out does it do that in Media player?
  • Sleddriver1
    January 28, 2007 at 12:45 am
    Yes. The AVI file is DEAD in the audio track. But, I did find a bit of a workaround. I rendered the video only, then rendered the audio only, then pulled the two into PP7 and rendered a finished product. Frustrating to have to do this, but at least it worked.
