Activity › Forums › Adobe Premiere Pro › PP speed report
  • PP speed report
    Posted by Ron Pestes on February 22, 2012 at 4:21 am
    OK, I am just finishing up my first long program with PP 5.5 since converting over from FCP. Here are my findings:
    I did a one hour twenty two minute multicam project with EX and AVCHD footage. Dropped both into a multicam sequence and everything played in real time after adding color correction and Power Point slides. No problems at all. Workflow was very smooth. I estimate about a three hour time savings from FCP with all the transcoding time to get both cameras into the same codec so FC can do a multicam edit. This was all done on a Dell M6600 laptop with i7 2820q processor, 16 gig of RAM and Nvidia 3000m card.
    I can’t over state how much faster this was compared to FCP. I have heard on this forum that some people are having slow down issues with long programs but I did not have any at all.
    Hope this brings hope to some users thinking of switching over. I am very glad I did. Good Luck!
    ronpesteshdvideo.com
    Apple Certified Master Pro FCS 2
    Sony EX-3
    MacBook Pro
    Dell M6600
    New convert to Adobe CS5.5 Production Premium
    Ron Pestes replied 14 years, 6 months ago 4 Members · 19 Replies
  • 19 Replies
  • Tom Daigon
    February 22, 2012 at 5:01 am
    So, how long did it take to export that 1 hour and 22 minute show to a master file?
    Tom Daigon
    Avid DS / PrP / After Effects Editor
    http://www.hdshotsandcuts.com
    Mac Pro 3,1
    8 core
    10.6.8
    Nvidia Quadro 4000
    24 gigs ram
    Maxx Digital / Areca 8tb. raid
    Kona 3
  • Ron Pestes
    February 22, 2012 at 5:06 am
    Have not exported yet. Still have the closing credits to do. I also need about 6 more slides that the client has not given me yet. Done soon though.
    Sony EX-3
    MacBook Pro
    Dell M6600
  • Erik Mickelson
    February 22, 2012 at 6:22 pm
    Yep, Premiere is a GREAT cutter of imported formats.
    Exporting…not so much.
    I’m with Tom in that I am curious of your export times. Very curious…
    I may try to develop a workflow with Premiere Pro straight cuts, EDL export to FCP and finish up there. Not sure if it will be of benefit though. I do a lot of supers and Premiere is the worst at transitions for supers.
    CrippleBook Pro 2.3Ghz i7, 8GB ram, SLeopard 10.6.8, FCPStudio 3, QT 7
  • Ron Pestes
    February 22, 2012 at 6:31 pm
    I will update this when I export which will be a few days yet as other projects are on the table first. It will also be only a DVD export so keep that in mind.
    Sony EX-3
    MacBook Pro
    Dell M6600
  • Erik Mickelson
    February 22, 2012 at 6:36 pm
    Your going to first export to a codec like DNXHD or Cineform correct? Then encode the DVD with Media Encoder, right?
  • Tom Daigon
    February 22, 2012 at 6:55 pm
    Ron, like Eric said. Its a REALLY good idea to create a master file (DNxHD is my new favorite alternative to Prores) then make a MPEG2 file from that for use in making your DVD. Its always nice to have that master files around when you need it.
    Tom Daigon
    Mac Pro 3,1
    8 core
    10.6.8
    Nvidia Quadro 4000
    24 gigs ram
    Kona 3
  • Eric Jurgenson
    February 22, 2012 at 8:43 pm
    OK, I’m curious.
    1) Why is Premiere worse than FCP with super transitions?
    2) Why do you feel it is necessary to export a master file in order to export an MPEG2-DVD file? (especially if this is a speed contest).
  • Erik Mickelson
    February 22, 2012 at 9:23 pm
    Premiere is worse the FCP in transitions because….
    You can’t save.
    Custom wipe does not remember where the gradient came from.
    Very few that can go on the end of a super(PC has Spicemaster, Mac does not have this option(closed API?)).
    The transition suffering list can go on forever.
    I almost ALWAYS export a Master HD file. You can then make 20 different flavors of export in Media Encoder or Compressor(export two different sizes of h264, mpeg2 and a quicktime in the same batch). Without the high res Master file you would have to render out of Premiere multiple times for all of those different formats and that, my friend, would take forever.
  • Tom Daigon
    February 22, 2012 at 9:59 pm
    Years of working at large and small video production facilities have taught me to ALWAYS create a master, whether on tape or now, a file.
    If you are familiar with Murphy’s Law you will understand one good reason. The other is you can make quick copies for various uses from a master done at a high resolution. And if your system goes down you dont have to relie on project files to have access to the video.
    Its the smart thing to do. 😀
    Tom Daigon
    Mac Pro 3,1
    8 core
    10.6.8
    Nvidia Quadro 4000
    24 gigs ram
    Kona 3
  • Erik Mickelson
    February 22, 2012 at 10:07 pm
    What he said. Tom has much more tact, and patience than I.
