Activity Forums Adobe Premiere Pro PP saying footage is proxy when it isn’t
  • PP saying footage is proxy when it isn’t
    Posted by Rich Birket on September 27, 2016 at 8:38 am
    Hi. I am using PP CC 2015.4 to create a short 4 minute film. There are quite a number of clips in the film from a couple of different cameras.
    When I try to export the sequence, PP comes up with a warning:-
    “Offline material is present in this export and has online proxies attached….”
    I did have a mess around with proxies at some earlier stage in the project, but it all went a bit pear-shaped so I ended up manually replacing the clips with the original versions to try and clear things up. It seems to play fine in the sequence.
    BUT, when I right-click on some of the clips in the sequence and select ‘properties’, PP tells me the clip is offline:-
    “Offline: Importer Can’t Open”. The file path to the clips in this same dialogue is pointing to a proxy version that I created at a lower resolution. The thing is that the clip isn’t the proxy – when I right-click on the same clip and choose ‘Reveal in project’, the full-res original clip is highlighted.
    It seems that Premiere has become confused.
    Any ideas? Hopefully the attached screengrab will help explain.
    Kind Regards,
    Rich
    Rich Birket replied 9 years, 12 months ago 1 Member · 0 Replies
  • 0 Replies
