Activity Forums Adobe Premiere Pro PP CS6 264 export rewrapped MOV stutters in re-import in PP
  • PP CS6 264 export rewrapped MOV stutters in re-import in PP
    Posted by Andy Milne on August 7, 2012 at 11:08 pm
    Hi All
    I have a PAL DV interlace lower sequence I am exporting at 1024×576 to a 264 file. The final file required is a QT but when you export an interlaced sequence from PP in QT the rendered file has a progressive flag even though the file is still progressive.
    So I render a 264 then use FFMPEG to re-wrap the 264 to MOV. This file plays fine in WMP & VLC but if you re-import into Premiere it starts to play fine but then stutters. Re-importing the rendered 264 plays back fine.
    If I render the sequence as QT MOV from Premiere it re-imports fine but has a progressive flag on the file.
    Anyone come across this?
    Cheers
    Andy
    Andy Milne replied 14 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
