Activity Forums Adobe Premiere Pro PP CS 2015: Take clips from larger video files but NOT import / conform entire video.
  • PP CS 2015: Take clips from larger video files but NOT import / conform entire video.
    Posted by Jim Guteriez on February 2, 2016 at 9:04 pm
    Im on PC Adobe Premier Pro CC 2015 and have a question i have not been able to search out a solution to (nor find someone with a similar question, although i know it has to be a common issue).
    I have several 3-5hour clips (10-20 GB each), from which i need to grab one or two 5 minute clips from, to then use in a PP project.
    How can I pull or import just the 5 minute blocks of video from these larger clips, without having to import or conform the entire 5 hour clip?
    Another way to state this question (with time-code examples):
    ie I have a 14gb 5hourVideo.avi i need to extract just 3h 42m to 3h 38m, and use that clip in my PP project. Currently i would have to import (or drag into my media bin / media browser) the entire 5 hour, 14GB video , then cut out my clip. When i do this PP begins conforming the entire 14GB video (as it should), is their a way to import just the 3h 42m to 3h 38m so the entire file is not conformed? ( i need to do this same function from several 5 hour .avi video clips).
    Peter Garaway replied 10 years, 6 months ago 4 Members · 3 Replies
