Activity Forums Adobe Premiere Pro PP crashes – Message says “this project requires third party components” Help?
  • PP crashes – Message says “this project requires third party components” Help?
    Posted by Jason Perryman on October 2, 2021 at 2:21 pm
    It seems I need to find a correct plugin for the Premiere program to play .DV files now but I don’t know what plug in, or where to find it. Can anyone help?
    As my Project crashes within 1-2 minutes of starting it up, but with this message coming up beforehand when I go to start it…
    “The preset used by one or more sequences in this project requires third party components that could not be located. These sequences will be modified to use a custom sequence setting instead. To continue editing using the original preset, quit the application without saving the project, reinstall any third-party components that are required to open the project.”
    Looking at my timeline before the crash I see that the clips that are .DV are brown and I think need relinking? (Though there is no window beforehand telling me that these files are offline)
    I cannot import .DV clips into a new project that I make. So PP can no longer accept/play them for some reason. However my Mac can play .DV files via Quicktime.
    I have no idea what 3rd party plugin is needed to play .DV files in PP, does anyone know what they are or where to get them?
    I use Adobe PP 2018. (Was told that going back to the 2017 version would do the trick but don’t know how to do that, or if I still can)
    A few months ago I did an upgrade on my 2016 Macbook Pro from El Capitan to Big Sur. I am not sure what that did to things, as I don’t believe I did a PP update as well.
    I didn’t moved any project files on my external hard drive to a new location either.
    If anyone can help I would be so grateful as this is causing me unnecessary time and stress and the Adobe Chat help didn’t solve this for me either.
    Jason Perryman replied 4 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
