Activity › Forums › Adobe Premiere Pro › PP CC — sloggish realtime playback of proxy video files
  • PP CC — sloggish realtime playback of proxy video files
    Posted by Joel Dalls on October 3, 2013 at 4:27 pm
    Hi!
    I am running PP CC on a 64 bit Service Pack 1 Win 7 Dell T3500 Intel Xeon CPU 2.67 GHz with 12 GB RAM and 2 HDD’s (Media on a striped 2 TB and application on a 500GB system drive).
    I have a 2 hour long film of which about an hour is complete (inside about 25 sequences in the PP project file). It consists of many rendered after effects clips which I have output to low res, WMV video only proxy files (typically less than 10 MB). On a side note, I have rendered companion JPG image sequences for these which are offline for now which will be exchanged with the WMV files when I do the final output.
    My problem is I am having problems getting real-time playback of the low res proxy WMV files. My resource monitor shows plenty of available RAM and only about 50% CPU use.
    I have tested other proxy file formats/settings like MP4 and they do not playback any smoother (and result in about double the file size).
    Any suggestions on a file format / output settings for a proxy file that will give me consistent realtime payback?
    Thanks so much in advance.
    Joel Dalls replied 12 years, 12 months ago 2 Members · 2 Replies
  • Kevin Monahan
    October 3, 2013 at 4:33 pm
    Hi Joel,
    Do the sequence settings match the clip settings precisely? Did you drop a clip on the new item button or right click it to select the “Create New Sequence from Clip” option?
    Kevin
    Kevin Monahan
    Social Support Lead
    Adobe After Effects
    Adobe Premiere Pro
    Adobe Systems, Inc.
    Follow Me on Twitter!
  • Joel Dalls
    October 3, 2013 at 5:00 pm
    I actually started out using QT .mov files rendered with H.264 and have been replacing those with the .wmv files … so the sequences were established using those original .mov/H.264 files.
    In the last few minutes, I have been testing proxy files rendered with the H.264 / MP4 format 8mbps VBR 1 Pass setting and they appear to playback without hiccups.
    Although the result is about double the file size. if they will consistently replay in realtime maybe I should switch to this.
    Back to your point … do I need to change each sequence to match these new H.264 clips and what will happen when I replace these H.264 MP4 files when I replace them with my master JPG image sequences?
    Thanks so much for your help.
