PP CC: Go directly to master clip from copied clip
Hi!
I’m using Premiere Pro CC.
I had several long clips from which I created lots of shorter copies (subclips), renamed them and put them into category folders.
From using Avid Media Composer I’m used to go quickly from a clip copy to it’s corresponding master clip (e.g. if I know that there was something else in this master clip I want to see right now without having to look for the other subclip / clip copy).
Is there any possibility in Premiere Pro to jump from the clip copy (/subclip) in the source window or in the media window to the corresponding master clip in the project (I don’t want to see it in the finder but within Premiere Pro)?
Thank you!
