Activity Forums Adobe Premiere Pro PP 2019 – exports not embedding time code
  • PP 2019 – exports not embedding time code
    Posted by Ivan Nabereznyj on August 26, 2019 at 8:26 pm
    Using the most up-to-date PP and brought in a QT that has 0-hour TC start but has BITC at 00:59:40:00. Want to export new video with embedded TC to match BITC. Have change all settings to start at 00:59:40:00 but cannot get an export with proper time start.
    Attached is a series of screen grabs with the various time code set 00:59:40:00 and a sample output:
    13661_pp2019embednotworking.png.zip
    Thanks in advance,
    Ivan (john)
    Ivan Nabereznyj replied 7 years ago 3 Members · 5 Replies
  • Tero Ahlfors
    August 27, 2019 at 7:23 am
    QT Pro has been dead for a while and I’m not sure it reads timecode from .mp4 files. If you bring the file back to Premiere does it have the timecode?
  • Ivan Nabereznyj
    August 27, 2019 at 8:13 am
    Thanks, Tero. No, the time code is still 0-hour when I bring back into PP.
    QT Pro may be dead from a development standpoint but it still is useful in telling me what audio, video and time code streams I’m dealing with. And is good for quick and dirty cutdowns.
    I use several different pieces of software and if QT Pro tells me there’s no embedded TC then none of them see embedded TC.
    Alternatively is there a way to export as and .mov file? Maybe that would embed the TC properly.
    Thank you for your guidance.
    Ivan (John)
  • Doug Metz
    August 27, 2019 at 8:50 pm
    EDIT – misread OP. Whoops!
  • Doug Metz
    August 27, 2019 at 9:27 pm
    { Ivan Nabereznyj }Alternatively is there a way to export as and .mov file? Maybe that would embed the TC properly.
    I just had a go at this – with your start time edited to your beginning BITC, exporting as .mov does the trick!
    Doug Metz
    Dalton Agency
  • Ivan Nabereznyj
    August 27, 2019 at 10:47 pm
    Yes, Doug, that does the trick. I kept exporting same as source and that was the downfall.
    Thank for your help!
    Ivan
