Activity › Forums › Apple Final Cut Pro Legacy › powerpoint to video for editing on FCP and later convert to flv
Posted by Zuleide Otaviana on December 16, 2008 at 2:11 amWhat is the best way to convert powerpoint slides to video to be edited in FCP? I will need to have high quality graphics. I will convert it later to flv. Thanks.
Stace Carter replied 17 years, 8 months ago 3 Members · 2 Replies -
Tom Brooks
December 16, 2008 at 12:23 pmPersonally, I take it into Keynote. You have to watch out for changes that Keynote might introduce if it doesn’t have the fonts or effects used in PowerPoint. Sometimes you will see text boxes that have cropped some of the text off the bottom and you’ll need to extend the boundary of the box to see the text.
From Keynote, you can export TIFFs or QuickTime movies. The reason I use Keynote is that, as of the recent past anyway, it makes better anti-aliased fonts on exported TIFFs than PowerPoint on a PC. It’s possible that PPT on the Mac will also handle fonts better and for that matter PPT on a PC may have caught up by now.
With a square pixel format, such as HD, you can set up your show to match the size and aspect. In SD formats, if exporting stills, you might want to resize them in Photoshop to be the correct aspect in FCP. In NTSC land I export 720×540 and then resize to 720×480 for SD projects.
Final Cut Pro 6.0.5, Mac OS-X 10.5.5, Quicktime 7.5.5, Adobe Prod Prem CS4, G5 Quad 2.5, Kona-LHe V6, 8.5GB RAM, Nvidia GeForce 7800-GT 256MB, G-RAID 2x1TB FW800, 6TB RAID-5 (Enhance E8-ML, Highpoint 2322), Panasonic HVX-200P P2. Also MBP 17″ Core 2 Duo 2.5, 4GB, GeForce 8600M GT 512MB.
Stace Carter
December 16, 2008 at 2:38 pmOr if you don’t have Keynote, save the PPT presentation to a new folder as JPGs and that will yield you and image sequence you can import to FCP. You’ll lose animations, etc.
here’s more detail on a Keynote method:
https://www.eventdv.net/Articles/ReadArticle.aspx?ArticleID=49665
