Activity › Forums › Apple Final Cut Pro Legacy › Powerpoint and 1080P
  • Powerpoint and 1080P
    Posted by Carmine Falzarano on September 21, 2010 at 9:16 pm
    Thank you in advance for your time and expertise.
    I shot a presentation in 1080p video. There’s an accompanying PowerPoint presentation… You know what’s coming don’t you? I need to cut the PowerPoint slides and 1080P footage together and get it on a DVD for my client.
    Anyone that can provide some pointers or solutions here I’d appreciate it. My approach is going to be be to convert the slides to PNG, JPG or another graphic format and insert them into a 1080P FCP timeline.
    Any suggestions, tips or other workflow ideas? Have I told the experts here what awesome and generous people they are for sharing their valuable knowledge with us?
    Carmine
    ________________________
    MacPro 2 X 2.266 Quad
    8 GB
    10.6.2
    Final Cut Studio 2
    Jeremy Garchow replied 16 years ago 5 Members · 7 Replies
  • 7 Replies
  • John Fishback
    September 21, 2010 at 9:21 pm
    I’ve found pngs to be much better than jpeg exports from PPT. Depending on the aspect of the PPT in FCP you may have to use the Distort tool in the Motion tab to adjust.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
  • Carmine Falzarano
    September 21, 2010 at 9:58 pm
    Thanks! I’m sure that will help.
  • Chris Tompkins
    September 22, 2010 at 12:51 pm
    I second that, always make png outta PP.
    Now, you can put a 1080 size grfx background under the smaller then 1080 PP slide in the timeline.
    Chris Tompkins
    Video Atlanta
  • Jeremy Garchow
    September 22, 2010 at 1:04 pm
    Man, it’s been a while, bit I used to rent a scan converter and play the PPT out in real time and record that. The few times I did it, they were really well done ppt presentations so they moved and transitioned and I needed that to be recorded in real time.
    Don’t know if you need that kind of situation but thought I’d throw it out there.
  • Carmine Falzarano
    September 22, 2010 at 3:13 pm
    These are your basic text and a few diagrams. I’m guessing the png with a graphic background to fill the frame is the way to go.
    Thanks everyone!
  • Rafael Amador
    September 22, 2010 at 3:25 pm
    And why don’t you just export the PP as a movie.
    Set the size and you get an Animation with all the original effects.
    rafael
    http://www.nagavideo.com
  • Jeremy Garchow
    September 22, 2010 at 3:26 pm
    [Rafael Amador] “And why don’t you just export the PP as a movie.
    Set the size and you get an Animation with all the original effects.”
    Every time I did that, it didn’t work well and things get screwy. That’s why a scan converter was the cleanest way.
