Activity Forums Blackmagic Design powering blackmagic converter with v-lock battery
  • powering blackmagic converter with v-lock battery
    Posted by Timvideo Ahern on August 29, 2012 at 10:46 pm
    I am looking at getting a little connector made to go from the d-tap connecter on a v-lock battery mounting plate to my Blackmagic Design mini converter (SDI-HDMI). All the V-lock batts are 14.8v, the mini converter is 12v.
    Will the difference in voltage blow up my mini converter?
    Patrick Sproule replied 14 years ago 3 Members · 2 Replies
  • Hersh Burston
    August 30, 2012 at 11:36 pm
    Unfortunately Mini Converter SDI to HDMI cannot accept a 14.8V input. There are many third party D-Tap regulated connectors available. A Google search should find these for you.
    Regards,
    Hersh Burston
    Senior Product Manager
    Blackmagic Design
  • Patrick Sproule
    August 31, 2012 at 7:40 am
    We ran a bunch of them off 12v 4ah Gel Cells in the field – in particular the optical to SDI convertors. They ran for a full 8 hours without recharge. Might be a suitable option?
    Pat
