Activity Forums DaVinci Resolve Powergrades in all databases?
  • Powergrades in all databases?
    Posted by Laco Gaal on February 7, 2012 at 7:17 am
    is it possible, to see the saved powergrades in all databases?
    For example if I create a “vignette” preset, how can I see it in all of my databases?
    Ben Mills replied 12 years, 10 months ago 6 Members · 9 Replies
  • 9 Replies
  • Charlie Edison
    February 7, 2012 at 7:54 am
    Not directly,
    You’ll have to export what you want from the Powergrade or Still tab and then re-import into your new database..
    Export as DPX into a folder, you’ll notice another file that turns up there with an extension something .drx, This is the grading data for the still or powergrade.
    If that .drx travels with the still image, the grade will come along with the imported still..
    You can do that between systems, for example send a grade and the still to another facility..
    Of course, with in the same database you can copy back and forth between users in the gallery page.
  • Laco Gaal
    February 7, 2012 at 7:58 am
    thanks!
    I’ve went to “Export”, and then I saw the dpx extension, so I thought it will simply save the frame, but not the grade.
    Silly me!:) I should have gone further.
    Thanks Charlie
  • Gabriele Turchi
    February 7, 2012 at 2:47 pm
    while that we are talking stills :
    are the stills in the still store (so saved inside the session and not exported) “”invisible”” on the hard drive ?i save set a certain drive for the still store , i can’t finder them anywhere (i want to back up , but i cannot find them…)
    g
    Davinci Resolve Control Surface
    MacPro
    Cubix desktop 4
    2 Red Rockets
    GTX470+GTX470+GTX285
    24GB RAM
    HP Dreamcolor
    Panasonic 58PF Plasma
  • Laco Gaal
    February 7, 2012 at 2:50 pm
    tried searching including system files?
    https://img.skitch.com/20100510-dfjnqgm71kcghudp5e5wwibupg.jpg
    by the way, which PF series do you have? 20?
  • Dara Yem
    April 6, 2012 at 10:30 pm
    Hi Guys,
    quick question i export a .DPX files but somehow it got a little Apple COLOR symbol on it? Seem like all the DPX files i export it automatically stamp it to COLOR applicatio, How come? And when i click the DPX it will launch Apple Color. THanks
  • Juan Salvo
    April 6, 2012 at 10:37 pm
    Your os associates DPX files with apple color. It is an OS setting not to do with the davinci. If you don’t have Color installed it won’t do that.
    You can change association by pressing cmd-i while you have a dpx file selected in finder.
    Then where it says “open with” change it to your app of choice. Then click change all.
  • Dara Yem
    April 6, 2012 at 10:46 pm
    Thanks Juan! 1.If I sent as .DPX for Mocha for After Effect will the grade info carry with it to AE? 2. And also im sending this to another Resolve station..which should i should DPX..or TIFF?
    Thanks again! 🙂
  • Juan Salvo
    April 6, 2012 at 10:52 pm
    no the grade info doesn’t carry. if you’ve rendered out the shot the grade should be burned in. if you’re sending to another resolve station. copy your source media and export a project file. hopefully the operator on the other end knows what he is doing.
  • Ben Mills
    October 16, 2013 at 7:57 pm
    I’ve sent a still (dpx and drx files) over to a friend also using resolve, they’ve imported the still and its applied the grade I have used, but for some reason is not applying the LUT I have used.
    It should auto select the LUT I have used at my end shouldnt it as well as applying the grading info? He also has the same LUT at his end and its named the same.
    Many Thanks
