Power Point Verticals are Warping/Curling
I am doing SD video projects with dv video and importing power point graphics into PP7.0.
It seems if I go to tight to the edge of my tv cut off I get a curling on the top of the vertical slide that is layered on a back ground.Doing these videos I always run into vertical slides. Is there a better way to do vertical images importing into pp7.0 and not having warping problems? Note: Does not show up
on the video edit screen, only on a tv monitor.Any input would be great!
