Activity › Forums › Audio › power buzz in audio -removal of
  • power buzz in audio -removal of
    Posted by Alexander Palmer on July 26, 2012 at 1:49 am
    hi audio guys,
    i have a power buzz running through my audio in final cut express video file
    can someone please explain how to remove most of this using the basic apple and final cut express audio filters ??
    i have about 2 seconds of isolated power buzz to use
    kind thanks
    alex
    Peter Groom replied 14 years, 1 month ago 3 Members · 3 Replies
  • Peter Groom
    July 26, 2012 at 8:51 am
    HI Alexander.
    I dont use FCP (cant stand it – AVID boy myself) but there will be a hum filetr in the set of audio filters. You will probably need to select the mains freq youre on (50hz 60hz) and it should rip it off fairly well.
    Dedicated softwares like Isotope RX and spectral layers are designed for this sort of use and will do a better job, at a cost.
    Peter
    Post Production Dubbing Mixer
  • Jean-christophe Boulay
    July 26, 2012 at 6:47 pm
    Hi Alex,
    To elaborate on Peter’s answer with FCP open in front of me, in the “Hum Remover” filter you have a few controls. Frequency is not preset and can be scanned from 20Hz to 15kHz. You’ll still want to use either 50 or 60 to remove mains hum, depending on electrical standards where you recorded.
    The “Q” setting determines how wide your removal notches will be and can be left to preset to begin with. “Gain” determines by how much you’re reducing the hum so go as low as you can without losing material you actually want to keep. It’s preset to maximum reduction.
    Then you have selectable boxes to suppress each harmonic. You’ll probably have to tick the first one or two but beware that higher harmonics will start to cut into your real audio you probably want to keep and come in handy mostly with really nasty overdriven hum.
    Once you’ve eliminated the hum, you can try to lower the “Q” setting until it starts rearing its head again, go back up a tad and you’ll have preserved as much of the original audio as possible while killing the hum.
    IHTH,
    JC Boulay
    Technical Director
    Audio Z
    Montreal, Canada
    http://www.audioz.com
  • Peter Groom
    August 2, 2012 at 8:39 am
    Alexander – did you get your buzz removed?
    Peter
