Activity Forums Apple OS X Powebook G4 Onboard speakers not working, OS problem?
  • Powebook G4 Onboard speakers not working, OS problem?
    Posted by Phippers on March 2, 2007 at 12:15 am
    Im looking to buy a PowerBook G4, The guy Im buying it from says that the Onboard Speakers stopped working about a month ago, He has looked into it, and he says that the computor thinks there are headphones plugged into the headphone jack, so that no longer works either, He said it can be fixed with an OS update, He recomended 10.4.X Tiger, I looked over the computor, and other then that it works fine!!
    Is that legitimate, have you guys ever heard of that?
    Please respond quickly!
    Matt
    Mgrodzki replied 19 years, 5 months ago 4 Members · 3 Replies
  • 13 Create COW Profile Image
    13
    March 2, 2007 at 3:23 am
    The only way to tell is to boot it from a known good system, if it still doesn’t work it needs a new logic board
  • Chad Mitchell
    March 15, 2007 at 3:51 pm
    Hi Matt!
    I have the same problem on MY powerbook G4. It’s a jack problem. Right now I can put headphones in and out a couple of times and that usually fixes the problem. I have apple care and should really get this fixed!! Maybe yours is past the point of wiggling the jack now…?
    chad.
  • Mgrodzki
    March 24, 2007 at 9:45 pm
    I just had the same thing happen only the headphones do work. when they are in the sound volume button works when i unplug them, the sound volume is grey and i cannot use it?
