Activity Forums Adobe After Effects Posterize time with slider control?
  • Posterize time with slider control?
    Posted by Adam Lewen on June 21, 2020 at 7:48 am
    Hello all!
    I have a piece of footage I would like to make as a webcam/intercom.
    Effect-wise I am good.
    But I would like to have portions of it glitchy.
    Posterize time will be great here, but I would like a slider of some sort to be connected to it, to control areas where the glitches will be more/less or none…
    While writing this post I understand more, but I am weak with expressions.
    Anyone here knows how to direct me?
    Thank you so much!
    Adam Lewen replied 6 years, 2 months ago 2 Members · 2 Replies
  • Filip Vandueren
    June 21, 2020 at 11:12 am
    What do you want to keyframe ? The exact moments at which the framerate drops ? (then you might as well keyframe the framerate directly).
    Or more like a probability that it might glitch ?
    What kind of glitch do you want: a simple freeze, or something more jittery like the frames are out of order ?
  • Adam Lewen
    June 25, 2020 at 12:22 pm
    Eventually a friend put on a little data glitch plugin that did the trick.
    Thanks for the reply!
