Activity Forums Adobe After Effects Expressions Posterise time expression stops working on adjustment layer.
  • Posterise time expression stops working on adjustment layer.
    Posted by Merlin Nation on June 13, 2023 at 3:09 pm
    Hi everyone,
    I have inherited an after effects file with a posterise time expression on a turbulent displace adjustment layer to effect the layers underneath. The issue I have is that the effect stops working or ‘runs out’ at a certain point (frame 1020) in the timeline, but there are no keyframes there, or anything else that would effect it. It works fine up until that point.
    The expression is here: PosterizeTime(4); time*800’
    I’ve tried adjusting the numbers but that doesn’t seem to work and I don’t know a great deal about expressions so I’m stuck!
    If anyone has any ideas on how to fix this I would be really grateful.
    Thank you!
    Merlin
    Merlin Nation replied 3 years, 3 months ago 2 Members · 2 Replies
  • Dan Ebberts
    June 13, 2023 at 4:19 pm
    You’re probably running into integer overflow on the Evolution property. Try it this way:
    posterizeTime(4);
    (time*800)%32768
    You probably won’t notice where it repeats (where it used to stop). If you do, we may have to come up with some kind of blend operation.
  • Merlin Nation
    June 13, 2023 at 4:36 pm
    Amazing! That looks like it’s worked. Thanks Dan, much appreciated.
