Post workflow suggestions for XDCAM HD422 series
Hi all,
I’ll be supervising post for a new broadcast series being shot primarily on Sony PDW-F800, 1080p24. I don’t have a lot of experience with this, so I am looking for some advice or input.
Our plan is to offline and package in-house on FCP systems, sending it out-of-house for color correction, sound mix and, most likely, final tape mastering. There will be out-of-house animation as well.
In the past, for HD programs, we have transcoded HD camera footage to SD (DV codec) for offline editing, and either conformed our online sequence in house before an out-of-house color correction, or did the entire online conform and color out-of-house.
We are going to be purchasing the offline suite systems for this series. I have not finalized what specs would be required for these systems.
I am looking for advice on the best workflow strategy for our post. Is it a better idea to do invest in robust offline suite systems and do our offline editing with XDCAM HD422 50 MB/s Quicktime material, or transcode the material to DV for offline edit on suites that are good enough to handle SD, and then online conform the material after the edit is locked?
Given that the required drive space is approximately half for DV vs XDCAM HD422 material, I’m wondering:
– would render and/or Quicktime creation times be significantly greater for a XDCAM HD422 timeline vs DV timeline?
– are the system requirements to work with XDCAM HD422 material significantly more demanding?
– how much of a pain is it to conform motion effects from a DV offline to an HD online?I’m trying to base my evaluation on:
– cost of assistant editor + system time vs editor time
– system costs for an SD edit suite vs HD edit suite
– potential complications in conforming an SD edit timeline to an HD timelineAny feedback, advice or input is appreciated.
P.S. – If I get good responses, I’ll start new posts for input on my other anticipated questions of best sequence settings for with XDCAM HD422 material, and how to incorporate 30fps material from the Canon 5DmkII. This is going to be so much fun…
Thank you,
David
