Activity › Forums › Maxon Cinema 4D › post effects and relections alpha
  • post effects and relections alpha
    Posted by Graeme Pereira on March 5, 2007 at 12:31 pm
    Hi all
    This might be an easy answer. How do you render a pass of Post effects(glows) and reflections on a floor with an alpha.
    thanks
    graeme
    K_style replied 19 years, 6 months ago 3 Members · 2 Replies
  • Mylenium
    March 5, 2007 at 6:57 pm
    Reflections do not generate Alpha (as they are always spreading across the entire scene, their Alpah is identical to the object Alpha; even “black” areas are reflection in strict terms of the renderer) and Glows do not reflect. They should have a proper Alpah, though, and if you render the post effects to a separate layer under multipass it will be there.
    Mylenium
    [Pour Myl
  • K_style
    March 21, 2007 at 7:34 pm
    I tried turning on the post effects but it did not give me any alpha for the reflection. Basically I am trying to get a reflection on the floor, but render just the reflection and not the actual floor.
