Activity Forums VEGAS Pro Possible Vegas rendering bug — easy solution
  • Possible Vegas rendering bug — easy solution
    Posted by Don Gordoni on November 21, 2008 at 7:32 pm
    Last week I was able to work around rendering problems on an HDV 720-30P project that contained avi files, jpgs etc. by rendering each element to 720-30P and removing extranious media from the project. I had thought that the overall size of the project was causing render problems but it turns out that there is a known issue per Matt at Sony.
    Here is what solved the problem in Vegas Pro 8.0c:
    Options>Preferences>General>(very last radio button)”Enable no-recompress long-GOP rendering.
    If you experience rendering issues try unchecking this button.
    If you are making cuts only edits without any graphics or effects then you can leave it checked.
    BTW, I tried every other solution under the sun on four different systems that are all powerful and fast enough to handle the rendering job and this was the only trick that solved the problem.
    Joe Mantaratz replied 17 years, 10 months ago 2 Members · 1 Reply
  • Joe Mantaratz
    November 22, 2008 at 4:46 am
    Thank much for passing this along. You just never know when things like this will crop up. There are just too many variables in hardware and software to ever be bug free. But we can try. Thanks again for this one. I’ll file it away for sure.
    Joe
