Activity › Forums › VEGAS Pro › Possible to Run/Render with Sony Vegas 13 on a Windows Based Web Server?
  • Possible to Run/Render with Sony Vegas 13 on a Windows Based Web Server?
    Posted by Andrew Evans on June 1, 2016 at 9:08 am
    Hello, I was recently wondering if it is possible to run Sony Vegas 13 on a dedicated web server. I was thinking that although it will take time to setup if it works it will be worth it. The main reason I want to do this is because I want to make my render times faster, and I have already explored all settings through the program to increase speed, while keeping the quality at an acceptable level. Please let me know if this is possible. Thank you.
    James Hauge replied 10 years, 4 months ago 3 Members · 3 Replies
  • John Lenihan
    June 1, 2016 at 4:19 pm
    I have been running Sony vegas pro 13 on a windows server 12 for years and it works.
    I use remote access to access it from my desktop pc. I can remote it from out of the office and start and check on rendering jobs.
    John
    John Lenihan
    LeniCam Video Productions
    https://www.lenicamvideoproductions.com
  • Andrew Evans
    June 1, 2016 at 4:50 pm
    Alright, I have an option to go up to 52GB of ram on my server ( google free hosting $300 credit ) how much will be actually utilized by the 8 core machine when Exporting? ( Rough Estimate will be fine )
  • James Hauge
    June 2, 2016 at 9:40 am
    Aloha from Hawaii!
    I’ve been using an older (probably about 3 year old) windows based dell server, it has 32 gb of ram and 8 cpu cores (2.8 ghz). it never uses more then 3.5 gb of the memory… even when i’m rendering multiple files at one time…
    For example, I’m rendering two video files on it right now at the same time and it’s only using 2.94 gb of ram according to the system monitor and all the cores are at 100%…
    now, my rendering is basicly just converting it from one video format to another with a single video overlay and very minor audio effects (just adding a compressor)… so that may account for such a small amount of memory usage, i don’t know…
    Just my thoughts for all of you out there…
    I have had it going to up to 5 renders all at the same time, and it still used less then 4.5 gb of memory, though I don’t remember the exact amount..
    Hope this gives some insight for you…
