Activity Forums Apple Final Cut Pro Legacy possible to mix down 5.1 audio to stereo
  • possible to mix down 5.1 audio to stereo
    Posted by Erin Gurdziel on February 12, 2015 at 9:30 pm
    I’m working on a simple spot revision, but because we received faulty splits, have had to instead use the audio from 5.1/multichannel Quicktimes as splits for the rough cut. Nothing about the sound has changed apart from the placement of a couple sound effects. Can I export a stereo master using these 5.1 tracks? Or should it go back to the audio facility? Thanks!
    Michael Gissing replied 11 years, 6 months ago 2 Members · 1 Reply
  • Michael Gissing
    February 13, 2015 at 1:11 am
    If it is for broadcast then I recommend going back to the audio facility. Things like peak levels, signal phase and loudness metering are required and a simple foldown formula plus additional FX may not comply.
