Activity Forums Adobe After Effects Possible to make a script to create different size boxes from layers?
  • Possible to make a script to create different size boxes from layers?
    Posted by Joey Mcnamara on September 3, 2014 at 8:33 am
    Hi, I’d like to ask for some help in creating a (probably impossible to create) script in After Effects. I’ve never really used scripts before, and to be fair I’m not even sure if it’s a script I’m looking for; I basically want something that’ll do something similar to Photoshop’s Action setting, i.e. run a set series of commands for me.
    Basically, I’m just curious if I can create something that’ll do the following from an Illustrator file that has each of the 6 faces of the cube in separate layers (I’ll set the layers to 3D layers beforehand):
  • Bottom- rotate x axis +90
  • Top- rotate x axis -90
  • Left- rotate y axis +90
  • Right- rotate y axis -90
  • Front- don’t rotate
  • Back- rotate y +180
  • Attach the faces to make the cube with snapping enabled.
  • And if it’s possible, create a null and make it a parent of the 6 faces, either before running the script or during the script, and make it have a rotation of 0 at 0 seconds, and a rotation of 360 at 5 seconds. I’m not really that bothered about this part as it takes like 10 seconds tops to do, but I need to create a large amount of different sized 3D boxes to animate, and I’m hoping there’s a way to avoid doing it manually.
    Thanks.
Joey Mcnamara replied 12 years ago 2 Members · 2 Replies
  • We use anonymous cookies to give you the best experience we can.
