Activity Forums Adobe After Effects Possible to keep the actual resolution of a video when nesting?
  • Possible to keep the actual resolution of a video when nesting?
    Posted by Steven Dileo on July 5, 2012 at 2:07 am
    As the title says im trying to keep the original resolution of my layers when nesting.
    For example I have a layer named “movie” then I precompose it and name the precomposed layer “movie_precomp” now while in the “movie_precomp” composition I scale the layer “movie” down. now in a complete different composition I add in the “movie_precomp” as a layer and scale that up, it is now acting as if my scaled down “movie” layer in the “movie_precomp” is a lower resolution and I get the beautiful fuzziness
    I don’t know if this possible, I thought the “preserve resolution when nested” was the option I needed before I started this little project but apparently it is not. Unless there’s something I’m missing that would be awesome if resolutions of individual clips could be preserved when nesting.
    Any help is appreciated, thanks!
    Steven Dileo replied 14 years, 2 months ago 2 Members · 2 Replies
  • John Cuevas
    July 5, 2012 at 2:47 am
    What you are talking about is the collapse transformations function. It’s the button that looks like a little sunburst. What it does is allow you to precompose assets, but it preserves the assets original settings.
    Here’s a tutorial about Collapse Transformation
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Steven Dileo
    July 5, 2012 at 3:10 am
    I just tried the little sunburst looking switch and it screwed up my precomp. inside the precomp are 3d layers and when I turn on the switch it throws everything off. I’m going to watch the video about The Naked Truth About Collapse Transformations and see if theres anything in there
    edit: the resolution didn’t seem to fix with the switch turned on either
    edit2: just watched the video and it was pretty interesting! Although not useful to solving my problem because turning on the collapse transformation re-turns the layers into 3d layers which is something I was trying to avoid in the first place by pre-composing. So I’ll just think its safe to assume that what I am trying to do isn’t possible and just start working on another way. Thanks for the reply though!
