Activity › Forums › Adobe After Effects › Possible to import AI layers and path (not an AICB question)
  • Possible to import AI layers and path (not an AICB question)
    Posted by John Ordelheide on April 11, 2005 at 10:02 pm
    I would like to be able to import a layer with it’s path intact to be able to do flash like illustrations with in AE. Right now I can import the AI file as a comp and then copy the paths over from each layer and paste them into the appropriate layer in AE. If I need to change the mask as I am animating and make it smaller it works well but if I need to expand the mask then there is not enough layer and I have a problem. I know that I can simply paste the mask into a new layer in AE but then I have to duplicate the coloring or gradients etc. that I setup in Illustrator.
    Steve Roberts replied 21 years, 5 months ago 2 Members · 1 Reply
  • Steve Roberts
    April 12, 2005 at 3:19 am
    Can’t you just scale up the layer from the imported Illustrator comp? If you want it to be sharp, you can click the “continuous rasterization” switch.
    Unless I’ve misunderstood you.
    Steve
