Activity › Forums › Adobe Premiere Pro › Possible to change several clips at a time in multicam edit?
  • Possible to change several clips at a time in multicam edit?
    Posted by Tl Westgate on August 2, 2012 at 8:37 pm
    We have a multicam sequence with dozens of edits. We need to be able to change the camera on all of them instead of right-clicking on each one individually.
    Yes, I know it would just take a few minutes to right-click on 50+ clips, but apparently this is on 30 different sequences, each over an hour. So it’s going to take a long time to do it manually.
    I’ve searched here and on the net to no avail. I tried selecting multiple clips and choosing MultiCam when right-clicked, but you can’t change the camera on more than one clip at a time.
    Any suggestions?
    — TL
    Alex Udell replied 14 years, 1 month ago 2 Members · 2 Replies
  • Alex Udell
    August 5, 2012 at 4:31 pm
    If you’re changing one camera angle to another….
    can you switch the angles around on the source multicam seqeunce?
    this would then result in all your edits referring to that track/cam…..to the replacement angle…
    Alex
  • Alex Udell
    August 5, 2012 at 4:42 pm
    also if it’s just for a section of the multicam…. and not all the edits….
    you can always just edit that section of the source sequence leaving the rest of that source/angle track in tact….
    Alex
