Activity Forums JVC Cameras possible to capture non-59.94fps footage into Final Cut?
  • possible to capture non-59.94fps footage into Final Cut?
    Posted by Bobby Mosaedi on January 15, 2009 at 11:46 pm
    We shoot a lot of material with the JVC camera in 24p/23.98 and acquire using a HDMI to HD-SDI converter to capture the footage into final cut. The only problem I have is that I hate having to capture nearly three times the amount of frames, then having to use compressor to re-encode everything. Big pain. Does anyone have a non-HDV workflow that allows you to capture JVC 720 footage either at 24/23.98p or 29.97p? thanks
    Bobby Mosaedi
    Magic Video, Inc.
    Bobby Mosaedi replied 17 years, 7 months ago 2 Members · 3 Replies
  • Johnny Clark
    January 29, 2009 at 3:56 am
    What camera are you using?
  • Bobby Mosaedi
    February 5, 2009 at 5:22 pm
    Im using the JVC GY- HD250’s HD-sdi output into a AJA LHe using AJA quick capture or FCP 6.0.5 with a HD Connect HDMI-HDSDI converter.
    Bobby Mosaedi
    Magic Video, Inc.
  • Bobby Mosaedi
    February 5, 2009 at 10:41 pm
    Ok, I figured it out… need to select the 1280×720 VFR instead of 1280×720 59.94 and just select the desired frame rate. Hooray!
    Bobby Mosaedi
    Magic Video, Inc.
