Activity Forums Adobe After Effects positioning 3 clips on a circel
  • positioning 3 clips on a circel
    Posted by Tielman Dewaele on August 26, 2008 at 9:29 am
    Hey,
    ive done this before, but i forgot how i did.
    I want to position 3 clips on a 3D circel path(mask maby) so i can rotate it.
    Every second the circel path turns end 1 of the clips shows up.
    How can i do that?
    T.
    MacPro Intel Quad Core 4G Ram
    MacBookPro Intel Duo Core 2G Ram
    After Effects, Photoshop, Illustrator
    Cinema4D
    Final Cut Studio
    https://www.t-bloggy.blogspot.com/
    Tielman Dewaele replied 18 years ago 2 Members · 5 Replies
  • Jerry Renes
    August 26, 2008 at 9:44 am
    I’m not sure how you want to position the clips on the circle but eitherway maybe this helps. You could create a null object. Then position the three clips all at the same distance from the anchorpoint of the null layer. Then parent the clips to the null layer. Now when you rotate the null layer the clips will seem to move as like they are on a circle path.
    If you want the clips to stay horizontal you could give the rotation an expression which is the negative value of the null object’s rotation value. (Or you could just keyframe this)
    Instead of the null object you could also use a circle shape if you want ofcourse.
    Good Luck!
  • Tielman Dewaele
    August 26, 2008 at 9:50 am
    Yes thats the method i usely use(see tut) but with 3 clips its different. They also have to rotate towards the camera, but auto orient along path is not an option because there is no path…
    Instead of the null object you could also use a circle shape if you want ofcourse. >
    Ho would i do that?
    T.
    Cinema4D
    Final Cut Studio
  • Tielman Dewaele
    August 26, 2008 at 9:53 am
    > how can i do that?
    Cinema4D
    Final Cut Studio
  • Jerry Renes
    August 26, 2008 at 9:57 am
    Well, unfortunately the animation is not quite clear to me. Is the circle seen exactly from the front? Do the clips also spin? Or are the clips just always parallel to the camera?
  • Tielman Dewaele
    August 26, 2008 at 10:05 am
    Nevermind,
    The parent method works.
    Thx anyways.
    T.
    Cinema4D
    Final Cut Studio
