Activity Forums Adobe After Effects Expressions position of highest alpha pixel
  • position of highest alpha pixel
    Posted by Adam Greenberg on April 4, 2023 at 6:49 pm
    Hi, I have to a new project that would require the user to import a graphic ( from a 3rd party ) and I would like to know if it is possible to have the position of a text layer appear 50 pixels ( for example ) above the top of this graphic. It could be a png, ai, etc.
    I would probably auto resize it with an expression I have used before.
    Is there a way to use sampleimage to look for the highest ( in regards to position ) alpha pixel ?
    Brie Clayton replied 3 years, 5 months ago 3 Members · 10 Replies
  • 10 Replies
  • Filip Vandueren
    April 5, 2023 at 7:11 am
    Hi Adam,
    there was a thread about this a few years ago:
    https://creativecow.net/forums/reply/2435715/#.ZC0d9tachSs.link
    it samples lines/columns from all four sides until it hits one that contains alpha information.
    It can be made faster with a binary search, but for precision while sampling and averaging out, you would again want the project to be at least 16bpc
    Reply To: Is there a way to know the width and height of a layer similar to sourceRectAtTime?
  • Filip Vandueren
    April 5, 2023 at 8:53 am
    Here it is with a faster binary (powers of 2) approach, only searching the top edge, up to pixel accuracy:
    posterizeTime(0);
    const l = thisComp.layer("Logo");
    const w = l.width;
    const h = l.height;
    const heightLog2 = Math.ceil(Math.log(h)/Math.log(2));
    const threshold = 1; // on average 1 pixel in a row is opaque to count as the topEdge;
    var topEdge = 0;
    for(i=heightLog2; i>-1; i--) {
    let partition = 2 ** i;
    let s = l.sampleImage([w / 2, topEdge+partition/2], [w / 2, partition/2], false, time);
    if (s[3]<=threshold/(w*partition)) topEdge+=partition;
    l.toComp([w/2, topEdge - 50]);
  • Adam Greenberg
    April 5, 2023 at 2:05 pm
    Amazing Filip, thanks so much.
    is there a way to have the x value constant ? I tried to replace the values with a number but it didnt’t work. I only need the height position to change.
  • Filip Vandueren
    April 5, 2023 at 3:44 pm
    the lastline could be something like:
    [960, l.toComp([w/2, topEdge])[1] -50 ];
  • Adam Greenberg
    my error, I think it was an anchor point issue on my end,
    thanks again Filip, this is a great expression
  • Adam Greenberg
    April 5, 2023 at 3:48 pm
    oh yes this works, I was entering that value in the wrong place.
    Thanks Filip !!!! ( for the 3rd time )
  • Adam Greenberg
    April 5, 2023 at 4:29 pm
    Filip, just for the math, could we do the same to find the bottom pixel and place something underneath ?
  • Adam Greenberg
    April 5, 2023 at 5:23 pm
    I have tried this but Im not sure it’s the most accurate way;
    [960, (h-l.toComp([w/2, topEdge])[1]+50) ];
  • Adam Greenberg
    April 5, 2023 at 6:43 pm
    ok this finds the bottom in case anyone needs it; ( thanks Filip )
    posterizeTime(0);
    const l = thisComp.layer(“TITRE_SHOW”);
    const w = l.width;
    const h = l.height;
    const threshold = 1; // on average 1 pixel in a row is opaque to count as the bottomEdge;
    var bottomEdge = h;
    for(i=heightLog2; i>-1; i–) { let partition = 2 ** i; let s = l.sampleImage([w / 2, bottomEdge-partition/2], [w / 2, partition/2], false, time); if (s[3]<=threshold/(w*partition)) bottomEdge-=partition; }
    [960, l.toComp([w/2, bottomEdge])[1]+50];
  • Brie Clayton
    April 7, 2023 at 1:53 am
    Thank you, Filip!
