Activity Forums Adobe After Effects Expressions Position any number of layers between two others
  • Position any number of layers between two others
    Posted by Jurij Magoga on May 18, 2009 at 8:55 am
    Hi, this is my first attempt to write an expression, i would like to get suggestions on how to improve it..
    I’ve found in AE help the expression to maintain one layer at a balanced distance between two other layers and i wanted it to work for any number of layers:
    x2 = thisComp.layer(“extr2”).transform.position[0];
    y2= thisComp.layer(“extr2”).transform.position[1];
    pos2 = thisComp.layer(“extr2”).transform.position;
    x1= thisComp.layer(“extr1”).transform.position[0];
    y1= thisComp.layer(“extr1”).transform.position[1];
    pos1= thisComp.layer(“extr1”).transform.position;
    if (x1 >= x2&&y1 >= y2){ (((pos1-pos2)*(index-1))/(thisComp.numLayers-2)+pos2)
    }else{
    if (x1 < x2&&y1 >= y2){ [(((x2-x1)*(index-1))/(thisComp.numLayers-2)+x1),(y1-((y1-y2)*(index-1))/(thisComp.numLayers-2))]
    }else{
    if (x1 < x2&&y1 < y2){ [(((x2-x1)*(index-1))/(thisComp.numLayers-2)+x1),(((y2-y1)*(index-1))/(thisComp.numLayers-2)+y1)] }else{ if (x1 > x2&&y1 < y2){ [(((x1-x2)*(index-1))/(thisComp.numLayers-2)+x2),(y2-((y2-y1)*(index-1))/(thisComp.numLayers-2))] } } } }
    This expression is for the position of the layers between the two layers(“extr2” and “extr1”).
    You can download the comp here:
    https://rapidshare.com/files/234297399/equidistanza_2_layer.aep.zip
    I will really appreciate any tip 🙂
    Jurij Magoga replied 17 years, 3 months ago 2 Members · 2 Replies
  • Dan Ebberts
    May 18, 2009 at 1:22 pm
    This assumes that extr1 and extr2 are at the bottom of the layer stack:
    P1 = thisComp.layer(“extr1”).transform.position;
    P2 = thisComp.layer(“extr2”).transform.position;
    P1 + (P2 -P1)*index/(thisComp.numLayers-1)
    Dan
  • Jurij Magoga
    May 18, 2009 at 1:54 pm
    wow!
    Thank you so much..
    actually the hardest thing is to keep the expression simple.
    Thanks again,
    Jurij
