Activity › Forums › Adobe After Effects Expressions › Position animation triggered by audio
  • Position animation triggered by audio
    Posted by Ivan Matic on July 16, 2021 at 7:11 pm
    I need to write expression for position that will be triggered when audio pass specific value and it can repeat multiple throw video.
    I tried with:
    if(thisComp.layer(“muzika”).effect(“Both Channels”)(“Slider”)>=85){
    [100,100]}
    else{[0,0]}
    And it works, but I want to add linear expression to y position, but dont know how to write to get time value
    Ivan Matic replied 5 years, 2 months ago 2 Members · 4 Replies
  • Yoan Boisjoli
    July 19, 2021 at 7:18 pm
    Hi Ivan !
    instead of [100, 100] you could write something like:
    linear(time, 0, 1, 0, 100)
    It converts time from 0 second to 1 second to the position 0 to 100. Feel free to play with the values. Also if you want something a bit smoother, you can change the word “linear” to ease, easeIn or easeOut
    Enjoy !
  • Ivan Matic
    July 19, 2021 at 8:18 pm
    Thanks for the answer, but what would happen if animation need to start again before previous one isnt finished.
    Animation need to follow bass on music, so i may happen there are overlapping
  • Ivan Matic
    July 20, 2021 at 2:46 pm
    Also if i writte expresion just with if and linear, it while now execute, beacuse next frame value is less then 85, and it back [0,0]
  • Ivan Matic
    July 21, 2021 at 2:33 pm
    I found solution that work for me, here is expression:
    threshold = 85.0;
    audioLev = thisComp.layer("Audio Amplitude").effect("Both Channels")("Slider");
    above = false;
    frame = Math.round(time / thisComp.frameDuration);
    while (true){
    t = frame * thisComp.frameDuration;
    if (above){
    if (audioLev.valueAtTime(t) < threshold){
    frame++;
    break;
    }else if (audioLev.valueAtTime(t) >= threshold){
    above = true;
    if (frame == 0){
    break;
    frame--
    if (! above){
    t = 0;
    }else{
    t = time - frame * thisComp.frameDuration;
    [easeOut(t,0,1/2.5,0,1920),value[1]]
