Activity Forums Adobe After Effects Expressions position a shape to the end of a text
  • position a shape to the end of a text
    Posted by Gerg Tolcs on September 23, 2015 at 3:47 pm
    Hi, maybe it’s not a real problem, I just want to ask you, maybe you have more experiences with this issue.
    I’m working with text and shape layers, and don’t use anything, just script files. I want to position a shape to the end of a text, position the next text to the ‘end’ of the shape, etc
    The text is changing, and I have to count the positions again and again.
    I use the sourceRectAtTime function, to find the end of the text layer, and a constant, to position the shape to the right coordinate. It’s ok, but not perfect.
    I realized, that the values from sourceRectAtTime are not the best for me. I made a little script (post it here, and of course, there are some exceptions 🙂 🙂 ) to look how it works, an I find, that last and first characters affect the width more than the others. MAGE.width != AMGE.width, but MAGE.width == MGAE.width
    Did you have what can I do – a shorter/easier way – to find the right place for my shapes in the center between two text layers, what are changing? Thank you!
    var myComp = app.project.activeItem;
    var abc = 'ABCDEFGHIJKLMNOPQRSTUVZ';
    var myText = myComp.layers.addText('');
    var textSource = myText.property("Source Text");
    var output3 = '';
    var word, letter1, letter2, resultNUM;
    for(var i=0; i<3; i++){
    letter1 = abc .substr(Math.floor(Math.random()*22),1);
    letter2 = abc .substr(Math.floor(Math.random()*22),1);
    for (var j=0; j<7; j++){
    word = '';
    for (var k=0; k>>
    P///29.9994142726064
    T///25.8761719800532
    !word - word : 4.12324229255319
    PB///79.7273905519396
    TB///76.933347530663
    !word - word : 2.79404302127659
    BP///80.8260233644396
    BT///74.845945186913
    !word - word : 5.98007817752659
    PAR///122.69540578872
    TAR///119.901362767443
    ARP///127.52939016372
    ART///120.414058079943
    !word - word : 7.11533208377659
    PACK///165.150729527697
    TACK///162.35668650642
    ACKP///171.387155361474
    ACKT///165.407077183947
    PCBJB///208.33436610736
    TCBJB///205.540323086083
    CBJBP///207.397158971056
    CBJBT///201.41708079353
    PVNIBQ///259.981576748192
    TVNIBQ///257.187533726916
    VNIBQP///261.838412633166
    VNIBQT///255.858334455639
    PKJJCLP///282.672342129052
    TKJJCLP///279.878299107775
    KJJCLPP///282.818826504052
    KJJCLPT///276.838748326525
    R///30.6585939601064
    M///29.9777344800532
    !word - word : 0.68085948005319
    RJ///59.9303201343864
    MJ///65.0830544568598
    !word - word : -5.15273432247341
    JR///70.8800271656364
    JM///72.0044411756098
    !word - word : -1.12441400997341
    RNK///126.529780736193
    MNK///131.682515058666
    NKR///125.907222142443
    NKM///127.031636152416
    RTLI///144.679538121447
    MTLI///150.96752635017
    !word - word : -6.28798822872341
    TLIR///153.285495152697
    TLIM///154.40990916267
    RJTLV///194.067080846056
    MJTLV///199.21981516853
    JTLVR///201.244815221056
    JTLVM///202.36922923103
    RISBJR///237.056772060692
    MISBJR///242.209506383166
    ISBJRR///235.251498570666
    ISBJRM///236.375912580639
    RQFGSPB///314.690002704039
    MQFGSPB///319.842737026513
    QFGSPBR///316.510217495263
    QFGSPBM///317.634631505236
    K///28.3406251575798
    Q///36.0052736476064
    !word - word : -7.66464849002659
    KI///58.5020974781364
    QI///65.8263162281364
    !word - word : -7.32421875
    IK///61.2012185193598
    IQ///66.9981912281364
    !word - word : -5.79697270877659
    KJV///106.754390111193
    QJV///114.078608861193
    JVK///112.602925214916
    JVQ///118.399897923693
    KIHM///163.576022496447
    QIHM///170.900241246447
    IHMK///166.27514353767
    IHMQ///172.072116246447
    KJLSC///190.697940221056
    QJLSC///198.022158971056
    JLSCK///197.31551829353
    JLSCQ///203.112491002306
    KUFPTU///259.567904820666
    QUFPTU///266.892123570666
    UFPTUK///262.230404768139
    UFPTUQ///268.027377476916
    KOASMTI///293.428088536486
    QOASMTI///300.752307286486
    OASMTIK///299.726916661486
    OASMTIQ///305.523889370263
    Kalleheikki Kannisto replied 10 years, 11 months ago 2 Members · 6 Replies
  • Gerg Tolcs
    September 23, 2015 at 3:49 pm
    “The text is changing” === Source Text is changing, not position, or anything else
  • Kalleheikki Kannisto
    September 23, 2015 at 4:06 pm
    Sounds very complex. If you can upload a picture or two of what you are trying to achieve, perhaps there is a whole different approach someone can suggest for the problem.
  • Gerg Tolcs
    September 24, 2015 at 8:17 am
    Maybe it will show my problem, thank you!
    September 24, 2015 at 9:02 am
    It is not an After Effects solution, but I would make this into a font with those shapes as characters, then you could type it in as text and everything else would be pretty straightforward.
    I use Fontlab’s FontoGrapher but there are some free font creation programs that should do it as well:
    https://mashable.com/2011/11/17/free-font-creation-tools/#TAsnSvmcZGkP
  • Gerg Tolcs
    September 24, 2015 at 9:21 am
    Great idea, but I’m afraid, It doesn’t work for me, It’s a lyric video, and all the 240 words contain these two characters. The Idea, that the shape chracters stays on the screen, and the other parts of the words appear and disappear, with animation, 3d position, opacity, etc, anything, I guess, impossible make it with one textlayer/word :/
    September 24, 2015 at 9:51 am
    I see. So you need the two shapes to smoothly move from one position to the next while the words around them change.
    How about creating the words with placehold characters with suitable spacing for the shapes such as bullet and asterisk with spaces on each side (” • ” and ” * “), then calculating the position of just those characters and animating the position of the shapes to match the positions of the bullet and the asterisk? You wouldn’t have to worry about spacing any of the characters in the words, just calculating those two locations in the consecutive words and animating the position of the shapes between them.
