Activity › Forums › Apple Final Cut Pro Legacy › Portable FW800 HD
  • Portable FW800 HD
    Posted by Jim on September 23, 2005 at 3:58 pm
    Does anyone know if there are portable FW800(7200RPM) drives.
    Something that could be powered by a laptop. Is such a thing possible, that is, can you get power for the drive via the FW800 cable? Also, if such a box does exist, any feed back on performance.
    I found a site that mentioned a Smartdisk 80GB FW800 portable, but there was no other tech info.
    Jim Cunningham
    cunninghamprod@sbcglobal.net
    Ed Dooley replied 21 years ago 3 Members · 2 Replies
  • Walter Biscardi
    September 23, 2005 at 4:09 pm
    You can something like the Firestore series which can run on a Anton Bauer battery, but it’s doubtful you can find anything fast enough for video that would also run off the laptop. It would kill the laptop battery so fast it would be impractical.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
    Now editing “Good Eats” in HD for the Food Network
    G5 Dual 2.0, AJA Kona 2, Medea FCR2X
  • Ed Dooley
    September 23, 2005 at 5:33 pm
    Wiebetech.com has a relatively new FW800 3.5″ 7,200RPM drive and enclosure that is buss powered. Walter’s right
    that it will use more power than a 2.5″ drive. They come in 120g and 160g versions.
    Ed
