Activity › Forums › Apple Final Cut Pro Legacy › popping & distortion with my audio in Final cut but not in Quick Time…
  • popping & distortion with my audio in Final cut but not in Quick Time…
    Posted by Christina Rule on March 4, 2013 at 9:02 pm
    When I’m exporting and playing back (inside FCP) my video out of Final Cut I’m noticing some popping and distortion with my audio. Now, when I playback the audio in quick time I’m not noticing any extra noise. I checked my sequence settings in quicktime and all seem to match up with the audio file settings. I can’t seem to figure it out…anyone have any ideas?
    Thanks in advance for your time and help!
    Here is a link to my screenshot: 5579_screenshot20130304at3.56.56pm.jpg.zip
    http://www.christinarule.com
    Christina Rule replied 13 years, 7 months ago 4 Members · 5 Replies
  • Jerry Wise
    March 4, 2013 at 9:31 pm
    try converting your mp3 to aif or wave. that might be the issue
  • Joseph Owens
    March 4, 2013 at 10:19 pm
    [Dave LaRonde] “I also have to ask why the sample rate is set to 44.1 kHz.”
    If the OP is using mp3s as source media in a video editing application, it may be attributable to thinking the audio sampling standard is the CD format of 44.1. Its pretty common for musicians and non-film-oriented sound mixers to carry this (erroneous) assumption. Also (erroneously) standard to submit digital audio files at “0” (full blast) instead of dynamically positioned for FCP’s internal reference at -12 or broadcast -20, which makes conforming to broadcast legal headroom, um, interesting. Maybe if the FCC were to fine a few more of them…
    jPo
    “I always pass on free advice — its never of any use to me” Oscar Wilde.
  • Christina Rule
    March 4, 2013 at 11:53 pm
    Thank you! That did the trick in regards to playback inside of FCP. However I’m still noticing when I export it the audio is really fuzzy… any ideas?
  • Nick Meyers
    March 4, 2013 at 11:54 pm
    “it may be attributable to thinking…”
    no thinking in it, it’s a standard music mp3 at 44.1k
    FCPX can deal with this and other formats, i believe.
    nick
  • Christina Rule
    March 5, 2013 at 12:12 am
    Never-mind, I realized I wasn’t exporting at the correct sample size. Once I changed this all sounded fine on the final export. Thank you all for all of your time and suggestions!
